Results 1 to 21 of 21
Thread: Longer pushrods
    Jan 2010
    Germany
    69
    Longer pushrods
    I am looking for longer pushrods for a C-90, I heard that there are pushrods available which are 0.03" longer.
    So I´m looking for a part number and where to buy.
    Any advice?
    Roger Peterson's Avatar
    May 2004
    Sweeny, Texas
    1,454
    If they are available, this guy can help you.
    Henry at El Reno Air Parts
    1-405-262-5191
    Feb 2011
    154
    I believe El Reno is no longer in business.
    Pushrods generally come in 3 lengths.
    They are identified by rings or p/n.
    Do you know what you have?
    Is this a cylinder change in progress?
    Jan 2010
    Germany
    69
    Yes I changed all cylinders. The rocker arms were changed too and I noticed that they were machined where they touch the valves. I checked the dry tappet clearance and I was right on the upper limit.
    The engine run great for the last 35 hours since the new cylinders were installed. It still runs good with a very slight vibration in cruise, but at idle power there is a kind of popping and I suspect that the valve clearance has increased some. Not sure but longer pushrods would bring me into the middle of the tappet clearance limits. At this time I don´t know the pushrod length but would say they are standard. I got new ones with the cylinders and they were exactly the same length.
    One more point: I just changed from straight mineral oil to W100.
    Chuck Avon's Avatar
    Apr 2011
    Hohenwald Tn
    366
    Checked my continental books and they show only one push rod part number for all C model engines the rocker arm being machined is were you got the increase in the valve gap but if your hydraulic lifters are working the gap is zero so as long as you are within spec they are good the popping at idle could be caused by a rich idle circuit the stromberg carb will tend to run a little rich and the extra fuel goes in the exhaust and when next valve opens you get a second explosion in the muffler hence the poping sound
    9,344
    I have used some that I believe are 70.000 over
    cubunltd's Avatar
    Mar 2004
    Belle Vernon,PA
    1,126
    The pushrods do come in various lengths. I believe they come in .030" increments. It's been awhile since I did a Continental but I did have to get longer pushrods to obtain the proper clearances.
    John
    9,344
    The longer pushrods are getting harder to get. Robert Weber had an old guy who used to make them for him but the guy died. We have talked for years about making a washer type shim the you could put under the cup in the tappet body to raise the cup doing the same thing as the longer pushrod. The adjusable pushrods in my Shovelhead looked like they would work.
    cubunltd's Avatar
    Mar 2004
    Belle Vernon,PA
    1,126
    How about going to an adjustable pushrod. There are kits available to make your own. Might have to get a field approval or Continentals approval but would be better than a shim in the lifter which would need some kind of approval also,,,unless you're Experimental.
    Shovelhead,,,right on!
    John
    skipster's Avatar
    Oct 2008
    Altamont NY
    198
    Continental is still making new 0-200's. Seems that they would make all parts available, including oversize push rods.
    17,924
    Look in your parts manual for the part numbers, several different lengths, and order from any good parts supplier.
    Feb 2011
    154
    They just might be listed in the Oversize Parts Section.
    I'll have to check.
    17,924
    Lots of good info on small Continentals.
    http://www.bowersflybaby.com/tech/fenton.htm
    Chuck Avon's Avatar
    Apr 2011
    Hohenwald Tn
    366
    Steve where in the parts manual did you find the listing for oversize push rods i have went threw both c75/0200 overhaul and parts manual for said engine and can't find any thing said about longer push rods at all also went threw A65 manual and nothing said there either. I think the large valve gap is caused when the cam follower and rocker arms were rebuilt do they not machine the face of the follower and the valve face on the rocker arm witch would make the valve gap wide and as far as adjustable push rods they are a oil passage to the rocker arms so oil has to flow threw them Oh went on harry Fentons site also no longer push rods there either
    Feb 2011
    154
    LESS Clearance is caused when the Valve Face & Seat are ground
    w/o doing the Rocker Arms.
    Typically this is found AFTER the cylinder is installed.
    If they are the "Standard" (shortest ) it means sending it back to the shop.
    nd
    2,988
    30ths longer than the 537870.http://www.aircraft-specialties.com/...od-537870p030/ price dosent seem right though.Then if thats to short i would try a new rocker arm.This is my OPINION like it or not.
    9,344
    New rockers are over 300 bucks each, five years ago they were 100.00 . We need one of the repair facilities that overhaul rockers to come up with an off center rocker pin bushing that gets them back to original specs.
    Jan 2010
    Germany
    69
    Are the oversize pushrods from Aircraft-Speciality certified - or experimental? .03 oversize will bring me in the center of the specification.
    nd
    2,988
    1-800-826-9252
    Jan 2010
    Germany
    69
    Ok, I ordered the oversize pushrods. I am confident that this solves the problem. Will report back when they are installed, might take three weeks or so.
    Jan 2010
    Germany
    69
    Here is an update: I got the oversize pushrods and installed them. Meanwhile I flew about two hours or so and all seems normal. Engine is smooth again and no strange sound.
    However the .03 oversize pushrods are more like .012 - .015" longer than my other pushrods and this is kind of disappointing because now I am still near the edge of the dry tappet valve clearance tolerance. And they were expensive with all the side costs! May be I have to look for .06 oversize pushrods!?
  1. No longer building an airplane!
    By JayH in forum Experimental Cubs
    Last Post: 12-01-2011, 03:43 PM
  2. longer tailspring / stringer to add stability
    By 750XL in forum Modifications
    Last Post: 10-23-2005, 09:17 PM
