Results 1 to 21 of 21
Thread: sight gauges
    Aug 2012
    12
    sight gauges
    Looking to install new fuel sight gauges,any preferances?
    Bugs66's Avatar
    Feb 2004
    Spokane WA
    2,309
    Experimental or certified? If experimental, I used Larry Bauer for mine:
    http://webpages.charter.net/calumetcub/catalog.html
    Aug 2012
    12
    certified and for a -18
    Apr 2007
    Kingsburg, CA
    1,256
    Dakota Cub
    18,286
    Dakota Cub, better visibility and they use o'rings which are easily replaceable instead of cork gaskets which require removing wing root covers, hose, etc. http://dakotacub.wordpress.com/2010/...-sight-gauges/
    nd
    3,102
    10,034
    http://www.fadodge.com/index.php?opt...stem&Itemid=53 only way to go if these are certified. Ops i see there only for atlees tanks.
    that's all I use, and field approve them to the different tanks... "deviated from STC by installing them on XX gallon tanks"
    May 2006
    308
    Steve, I have a set of each, which way is up for Dakota Cub and Piper? Seems to me that you should turn the Piper ones over from what you have shown to show fuel down to 0? And do you have a part number / source for the sleeve? And does the 'restricted' elbow go on the bottom? Don
    10,034
    Quote Originally Posted by Aerodon View Post
    best smaller part down.... not necessarily right...
    restrictor should be in BOTH incase of glass breakage.....
    May 2006
    308
    OK found out, the thick bolt goes on the bottom on the Dakota Cub fuel gauge. Makes sense that you can then remove the glass to replace O-rings without any further dissembly. I guess this logic could apply to the piper gauge too, but then the visibility at low fuel levels will be more restricted. There are no restrictors in the DC fuel gauge fittings. Don
    nd
    3,102
    Dakota cub builds the restrictors into there tanks. they weld the fitting on to the tank and drill a small hole through the inside of the fitting into the tank, that way if the fitting happens to break off the gas still comes out slower.
    18,286
    The factory gauges had the short end on the bottom along with the restricter.
    This is from the production line in the mid 1070s. The red elbow has the restrictor and the end with the flats is shorter that the end without for better visibility when low on fuel.
    39-J3's Avatar
    Sep 2008
    Maine
    520
    Is it possible to install a sight gauge in a J3 wing tank?
    Larry
    18,286
    I think Clarence Witte had an STC for it. Check with the new owner of his STCs, Scoot Air. http://www.scootairllc.com/website/wingtank.htm
    Found my list, They own all of these STCs but not sure that they have approval on all of them as of yet.
    SA1496GL J-3 12 Gallon wing tank
    SA00715CH Sight gauge for above tank
    SA01334CH J-5 19 gallon tank
    SA00805CH PA-12/-14 19 gallon tank
    SA01333CH PA-12 24 gallon tank
    SA1765GL J-3/PA-11 fixed and swing engine mounts
    SA01104CH PA-12,-14 swing engine mount
    Apr 2017
    24
    Mike, Any reason these sight tubes won’t work with the Dakota 24gal tanks?
    STC states 30.5 Atlee tanks
    Thks Adam
    cruiser's Avatar
    South Glens Falls, NY
    1,432
    Not sure that you can see thru the Dakota Cub gauge, although they are heads and shoulders above the Piper gauge with one exception if you cannot. Note how the fuel refracts the level lines behind the gauge when you can see thru it making it easy to confirm fuel level and/or that there is actually fuel in there. One member had an incident awhile ago around this issue and may offer his opinion based upon a well learned lesson, Jim
    2,262
    Make sure the 'little red ball' is installed and floats on the fuel. That's the original design and it works much better than looking for the fuel line itself.
    Apr 2017
    24
    Thanks for the heads up on the red cork ball. Had these on my Grumman but didn’t realize the Piper PA used the cork too
    Adam
    RaisedByWolves's Avatar
    Feb 2005
    3,679
    Here is the Dakota. You can see the fuel pretty good.
    Apr 2017
    24
    Looks good! Thks for posting the pic...
    3,236
    Do the Dakota gages fit the port spacing on Atlee 30.5 tanks?
  1. Sight tube gauges?
    By TJ400 in forum Experimental Cubs
    Last Post: 07-19-2007, 07:00 AM
  2. Sight Gauges
    By C-YQK in forum Experimental Cubs
    Last Post: 08-09-2006, 11:31 AM
  3. Sight gauges
    By j3jm in forum Cafe Supercub
    Last Post: 05-08-2004, 09:57 PM
