Results 1 to 11 of 11
Thread: Oil Sump Repairs?
    Oil Sump Repairs?
    While doing some maintenance on the cub this weekend I noticed two small cracks on the Oil sump. They are about one inch long and start under the flange on the front side of the tank. My question is should I find a serviceable oil sump or should I just have mine welded? The engine is a C85-8.
    Bushwhacker is less than two weeks away so I might have to hitch a ride with JP if I am not up and running by then.
    Larry
    Weld it. I've welded several. That is typically where they crack.
    It's not hard to weld as long as someone hasn't brazed it first
    It has not been welded or brazed it the area of the cracks. So it sounds like a good candidate for welding.
    Thanks for the replies.
    Larry
    Quote Originally Posted by 39-J3 View Post
    Larry
    Larry you need to get it really clean, wash the whole sump in parts washer or gas and then use carb cleaner or starting fluid to flush the oil out of the crack then wash it again with soap and water. NOTE don't weld anywhere near where you did the cleaning if you like your shop.
    Glenn, I was able to get over to Bowman this weekend and remove the oil tank. I have it prepped for welding and it looks like it will be an easy fix. Do you know what the alloy make up is of the oil tank? I am going to TIG weld it and was going to use 309 filler rod.
    Larry
    Larry
    I used a coat hanger.
    The tank is cold rolled steel 1018. Use eaither 1018 rod or chrome- moly rod. Why would you use stainless rod on mild steel?
    john
    I had one welded a while back. The welder was simply obsessive about cleaning the tank and the cracks.
    If you're going to TIG weld it then it has to be clean otherwise it will spit and sputter during the weld process and contaminate the weld
    I have not struck an arc in several years so I have decided to send it out to be welded. Cheap insurance for peace of mind. I should be picking the tank up tonight.
    Larry
  1. Wet sump
    By robair in forum Experimental Cubs
    Last Post: 02-27-2011, 02:19 PM
  2. 0-360 Oil Sump on a 0-320
    By Indabush in forum Cafe Supercub
    Last Post: 09-03-2010, 10:12 AM
  3. Oil sump on 0-320
    By PA-18 in forum Super Cub Sick Bay
    Last Post: 09-28-2005, 11:46 AM
