Results 1 to 11 of 11
Thread: L21B plate between carb and air box
    Anyone know what PN 73451-03 is (see picture attached)? Is it a gasket??? Is it a steel "plate"? Where can I get one? I called Univair they don't have that part number.
    It's a stiffener/spacer plate. Never seen one on an airplane. Yes there is a paper gasket and that is all I have ever dealt with. May have been used with some air-boxes as a spacer due to stud length from carburetor. If your air-box bolts up with out the studs hitting the top of the air-box then don't worry about it. Hardly any of these things are "Like Factory" anymore. Some air-box studs are coarse thread and some are fine thread. There are long and short ones too.
    Jason
    Is this part serial number specific? The Tri-Pacer has a spacer like this. I will have to look up my notes and a thread on ShortWingPipers.org. From memory though it was the difference in two different airboxes that piper made, the difference was the legth of the airbox neck. I will get the specifics and post.
    Henry Ford
    How's the L21B going? Posting any pictures anytime soon?
    Coming right along---getting ready to apply finish color onto fuselage, etc.
    Quote Originally Posted by SchulerJL View Post
    Doesn't seem to be serial number specific---just says "1 per airplane for "150"" The airplane we are working on is a "150".
    It is more like a gasket. 73451.pdf
    Henry Ford
    Can't wait to see it finished - good luck!
    Thanks I'll get more pictures up when I can.
    I saw that drawing as well-- looks like one of those is 7/16" thick! BTW what is Vellumoid is that anything like unatanium!
    Vellumoid is a type of gasket material. It is used for the gasket between the tail wheel halves and the friction washers on the throttles.
    Henry Ford
  1. L21B weight increase to 1,750?
    By 54tw in forum Modifications
    Last Post: 06-12-2005, 07:26 PM
