SEFYK
PATRON
Germany
The holes in my EDO float fittings (rear fitting at the aircraft P/N 69747) where the pins for the flying wires go through are worn out. On one side the hole is nearly double as long as it is wide. On the other side it is less.
Are there any limits for the elongation of these holes? How much material must be left between the hole and the end of the fitting?
Since new fittings are $$$ from Kenmore (and they do not sell the inner plate separately, only the whole fitting) I want to keep mine as long as possible.
