Results 1 to 7 of 7
Thread: Stab carry-through bush replacement
    Anyone have any suggestions as to how best replace the 2 brass bushes in each end of the front stabiliser carry through tube (Trim cross tube)? Iv tried 'lightly' drifting them but they wont move. I Cant drift too agressively for fear of crushing the tube in the vice or bending the attachment lugs. Next option is a bit of heat but thought Id check with the experts before going much further...?
    Mike,
    I think you miss read his question.... He is trying to replace the bushings in the "Carry through" tube mounted on the jack screw....
    Binty,
    I don't have an answer for you on that one.... Never seen one bad enough to warrant replacing.
    Brian.
    Quote Originally Posted by Steve's Aircraft (Brian) View Post
    Mike,
    Binty,
    Brian.
    yup, I misread that!!
    Brian.
    me neither....
    but split/slit brass bushing with hacksaw and it will come right out
    I have never replaced those bushings, but heat would be a last resort for me. The dimensions will change if heated to red hot, and would probably be hard to restore.
  1. Horizontal Stab tolerance between Stab and Trim yoke
    By GeneHerzog in forum Super Cub Sick Bay
    Last Post: 12-10-2007, 01:01 PM
  2. The last Piper to carry the cub name...
    By SJ in forum Cafe Supercub
    Last Post: 11-18-2005, 11:09 AM
  3. Carry-On
    By Jacob Papp in forum Cafe Supercub
    Last Post: 02-01-2005, 09:46 PM
