Finally getting back on the plane and making some progress.
The hole in the left side of the panel is to receive a fire dept 700 mhz handheld and also
have a tactical radio adapter installed so that it can be used as com 2.
I also just got my sample of Oratex fabric and ran a test cover on the top of a old rudder. Quick cut some tapes and put glue on them to try and see how the finishing tapes go on. I am sure theirs are lot better than mine. Also ran a test of applying fabric direct to alum and we thought we might try that as a alternative to painting the cowl and the bottom fuselage panels.
Results: Far better than expected. Glue is really strong. Probably the strongest I have ever used. Finish is great, no paint. No smell, everything works as advertised.
If the test of trying to take the fabric is a success, we will be using it on the fuselage and all the tail surfaces. Will remove the stewarts that is on the rudder and recover.
The wings are already to paint in Stewarts, so will try to match the paint to the Oratex.
As for covering the cowl. Looks like it will take the heat and the adhesion is great. Can't see a down side so far. Wish I hadn't bothered to do all the work on the inside with the Kydex as this would really save weight and would probably look lot better also.
Have been doing fabric work for years on everything from J3's to WWII bombers and fighters. Finally it looks like a system that takes the work out of it and is really light. Also the strongest fabric for the weight I have seen.
