Page 2 of 2 FirstFirst 12
Results 41 to 62 of 62
Thread: Wing Tip Shape Summary
  1. #41
    In my short experience:
    Droop tips suck. I found no lift advantage and the
    make it difficult to see past the wing from the cockpit
    These are the reasons I dont want to install the droop tips on my smith cub, mine came with the kit, has any one had experiance with no tips at all ? just fabric rap the end rib and maybe put a stall fence on the trailing top half of the tip rib, I have seen some represntations of this on a few other cubs, one of wayne Macky's early SQ2s had this, is there any advantage or disadvantage of doing it this way? would save a guy some money if he didnt have to buy wing tips, fabricating a fence would be a piece of cake.
    Rick
  2. #42
    Rick,
    I plan to do exactly that. But i will fabricate and end plate with the fence incorporated. When the supplier of my wing tips told me that they are aesthetic only, I wondered why I bothered putting them on. The small fence needs some research. Are there any pictures of wayne's?
    Back Country O-375 wide body extended wing cub
  3. #43
    Quote Originally Posted by Cajun Joe View Post
    Yeah, I guess that's the trick word..usually
    Of course I've bumped into a few things and
    nothing on the plane bounced back...cept me.
    Yeah Joe, I think I have pictures somewhere. If you would like, I'll try to dig them up. Who loves you Joe?
    Volunteer, in charge of Political Correctness
  4. #44
    Joe, I have a picture of Ron if you need a little "dig" on Ron.
    Henry Ford
  5. #45
    Hell Steve! The whole world has embarrassing pictures of me in a Super Cub. I'm kind of like the Paris Hilton of SC.Org. (Maybe I should rephrase that) I thank you in that, at least, you didn't have t-shirts and coffee mugs made from them.
    O.K. That's more posts in the last two days, than I've posted in the last two years. I think I'll go back into hibernation. Wake me for the OK18 Fly In.
  6. #46
    LOL, I am just enjoying you guys return. You haven't seen pictures of my adventures this summer.
    Henry Ford
  7. #47
    No, but I have heard stories.
  8. #48
    Rick, Super11xp on here has no wing tips, maybe he would chime in?
  9. #49
    Rick,
    Goldy,
    Here is the link to Wayne's early SQ2 review has some good pictures of his wing tips, or lack of !! I think a guy could fab the fence out of 1/8 lexon or plexy, would be paintable and easily repaceable if you were to say hit a branch or something Ha Ha !!
    http://www.eaa.org/sportaviationmag/...Backcounty.pdf
    Rick
  10. #50
    Goldy and Rick, The tip plate/fence is simple, but the advantage ends there. Wayne changed to a Sullivan/Hendricks style tip after testing revealed that the tip vortex with that tip fence/plate was hitting the top of the wing about 4 feet inboard of the tip....not a good thing.
    There is some discussion here. If you look hard enough, or someone does a search, there is discussion where Jerry Burr talked about his research and gave report to flying qualities of various tip designs. I believe the Sullivan tip ends up with highest marks...still, it's just a wingtip
  11. #51
    Dave,
    Do you think the Fence would be better served on the bottom of the trailing edge in a similar fashion to the one that Wayne had on his old SQ2 only inverted? that way the vortex would help create lift,( I am just thinking out loud here, I may me be way off in my thinking), would still resemble the Droop tips only smaller, less surface area and create less visual intrusion under the wing......Just a thought.
    Rick
  12. #52
    Steve, Ron y'all stop foolin around on this site.
    These guys are serious about this whole wing tip thingee...
    Check this out: "would still resemble the Droop tips only smaller,
    less surface area and create less visual intrusion under the wing....."
    Visual Intrusion!
    Steve, chew on that for awhile.
  13. #53
    I'm sorry rotto789; truly I am.
    I am a dear romantic when it comes to the English language
    and the cleverlessness of warping words..
    I thought your phrase "Visual Intrusion" was really neat
    and pointed it out to SP because he is a serious student
    of Cubisms.
    As far as how it relates to wings, I have no idea.
    As far as stupid comments go, speaking for Massey
    "he makes a lot of them."
  14. #54
    Southerner?
    Guess I'll join Massey and "hibernate" until OK18 rolls.
    Later
  15. #55
    Dang! After carefully 'splainin' to Joe some years ago the similar linguistic usage between "coonass" and "yooper" (i.e., either a term of endearment or fightin' words, depending on who sez it and in what tone, one meets t'other . And of course I enjoy both cultures. And this has been an interesting string.
    Rotto, you'll hafta do some research (lighter than air area, I believe), on a piece entitled approximately "Joe Moves ta' da' U.P." [Which Joe took with good grace and some fun banter.]
    Tanks, eh? cubscout
  16. #56
    I usually just tune you guys out. Between you and the nimpo/tango deal, I can't keep up with you......and wouldn't try if I could.
    Goldy, I don't know the answer to your question. Wouldn't hurt to experiment. Did you try using the search function for that Jerry Burr stuff about tips. Maybe he discussed it. I do recall a discussion of "splates", which I think is a tip plate.
  17. #57
    this would be a title NimpoCub's Avatar
    May 2006
    2,704
    DC, are you sayin' that you are somehow miffed @ the good-natured bantering between some of us?
    I kinda figgered it would elicit a smile, not "tuned out" irritation.
    SORRY if that's the case.
  18. #58
    I told you guy's this was right on the money I posted this last week, find your caracter
    This is an example of how we all get along somedays
    http://youtu.be/WjoDEQqyTig
  19. #59
    Hah, I am rarely "miffed" Logan.
    I read what everyone writes.......some of it gets tuned out. Most of what George writes gets "tuned out"...and Eaton
    I just don't have the mental capacity to comment on it all
  20. #60
    Glenn, if that's the birds on the wire, I got a kick out of that. True, true!
  21. #61
    Does anyone have the installation instructions for the Ferguson tips? "Upper Valley Aviation exhibit no. 2a report 101-250 dated august 30, 1965.
    Thanks in advance!
  22. #62
    Ferguson tips installation for pa-12 and others. The only number that corresponds is 8/30/65
    Not sure if it will help at all but...
    Attached Files Attached Files
  1. Weight difference between slotted wing and piper wing?
    By glassjet in forum Supercub Gatherings
    Last Post: 10-30-2007, 12:18 PM
  2. The Long Overdue New Holstein 2006 Survey Summary
    By SJ in forum Member to Member
    Last Post: 10-09-2006, 03:57 PM
