Lots of ways to actuate it....
Lots of ways to make this go. If I were Doug, I would be adding this to my RobbySTol 206 wing. I did it to a Cub with drooop ailerons, and it was a success. I have not even fiddled with it since the first flight,,,, it JUST WORKED! The scariness of a lightweight droop-aileron Cub with dubious control of roll and being left hanging with only rudder to save a prang is GONE if you have roll spoilers.
You made a statement above, not sure what you mean. "... increasing the down travel increases the angle of attack thus increasing the stall speed of that portion of the wing." Is that what you meant. "increasing" stall speed? Surely not.
Maybe the use of the term "stall speed" is not totally accurate.
So in effect the roll authority is degraded from the inefficiencies of both ailerons when drooped. Of course this will be most noticeable a minimum speeds.
I'll buy the above statement.
I would argue the statement "...increasing the stall speed..". in the context above.......That's all I meant. The rest is reasonable. I was just trying to see if you meant what I thought you said. In your descripton of the checkout scenario, is it possible that the left wing was in a rotor from the edge of the trees?? Just a question.
..anyway, this roll authority issue from a very slow flying a/c can be fixed by more "differential" aileron throw, and also a roll spoiler.....been there, done both of those ideas..works well. Will do it again.
The C208 Caravan has roll spoilers that work seemlessly with the airlerons. Could that archetecture be adopted for the 206 or 185?
Just as an added bit regarding aileron authority when on floats: Landing is pretty simple. If you have a gusty crosswind, stack on a little extra speed and simply run the airplane onto the water at higher speed.
Adding droopy ailerons will only add to the pitching moment problem. With the reduced roll authority, added pitching moment, and added weight, is it worth it? Dave, I get the spoiler idea and am interested, but I want to keep the airplane simple and light. If the project gets heavy it will not perform to my expectations. Added electrical motors to deploy droopy ailerons sounds more complicated and heavier than I may be able to swallow. I have already added a weight penalty with the206 wings, wing extensions, and sportsman cuff. I cannot let the weight get out of hand, it will already take a lot of work to offset the wing mods. Doug
...effectively "washed-IN". It would seem that if the a/c stalls during that climbbout, it will not stall straight ahead......because it a the wing tip that will stall before the wing root, and roll you over.
....... But then when you see the Canadian built new Skywagon, I'm thinking they went with the same wagon wing?.......
Like this? http://www3.sympatico.ca/st-justaviation/index.htmlAlmost 5 year old thread, but I'd like to hear more about the "Canadian built new skywagon".
this brings up another "problem" with the RSTOL. Because the Robby is so awesome. ...........Because the whole trailing edge is drooped the aircrafts pitch attitude is much lower (nose is lower than stock) when you "run it on with higher airspeed".....and you will be up on the toes of the floats if you run it on with more than "...a little extra...".
...just saying. I heard it said once.
