Oli, Of course it is your plane, whatever you prefer is the right thing.
The higher pressure air under the wing flows outward around the tip forming a spiral twisting action. This air pushes downward on the top of the most outboard trailing section of wing with unstable air. As a result when the aileron goes to the tip as yours does, the outboard few inches becomes ineffective. When you extend the wing the amount which I have suggested your aileron becomes more effective. This is in addition to the five or so extra square feet of lifting surface plus the improved performance of a higher aspect ratio wing. The higher aspect ratio will reduce stalling speed, increase rate of climb and in some cases increase cruise speeds in addition to improved high altitude performance.
The plates which you have on your tips would be more effective if they extended below the wing, effectively acting like a dam preventing the outward flow of air.
I did this on one of my airplanes with the idea that if I wasn't happy with it, it could be easily removed. 35 years later the extensions are still on the plane. You mentioned that you were itchy for a project, well here is one.
