Results 1 to 22 of 22
Thread: Electroair Announces Electronic Ignition System STC for 4-Cyl Lycomings
    18,286
    I got this announcement today. Looks interesting for the certified crowd.
    Electroair Announces STC for 4-Cyl Lycomings
    STC for Electronic Ignition System
    Howell, MI - Electroair is pleased to announce that is has received an STC for its four cylinder electronic ignition system. This initial STC covers Lycoming four cylinder engines installed on a wide range of airframes. STC information and approved models listed on the Electroair website.
    Performance Gains & Wide Range of Aircraft Supported
    Significant performance and economy improvements have been documented in use of Electroair's ignition systems, over 2,500 of which have been previously installed in experimental aircraft.
    This initial STC covers a wide range of aircraft including Cessnas, Pipers, Grummans, American Champions, Beechcraft, Mooneys and more. Many of you have been waiting for this list to be published. Click here to see the complete list of approved aircraft: Approved Model List
    To learn more, go to our website and click on the STC button. Complete installation instructions and technical support information is available. Kits are in stock at the factory or throughout our growing distribution network. Click, call or email if you have any questions.
    Flying Miss Daisy's Avatar
    Jun 2004
    Wentworth NH" The WAD" NH96
    3,255
    It appears the PA18 and PA18A 160 are not on the list.
    Life should not be a journey to the grave with the intention to arrive safely in a well preserved body but rather to slide in sideways, well used up proclaiming "WOW What a Ride"
    Meanwhile,...
    4,909
    Quote Originally Posted by Flying Miss Daisy View Post
    Since there is no type certificate for a PA18-160 and the approval is based on type certificates what would one need to do to "adjust" it for a 150 modified to be a 160?
    18,286
    Up to the installer to determine if one modification effects the other.
    Jun 2004
    3,255
    My engine was purchased as a factory new 160 and is not a conversion.
    John
    18,286
    The airframe has been altered by putting a 160 hp engine on it. Miss Daisy is still considered a PA18-150 in the eyes of the FAA. Electroair emailed me back and there STC is approved on a 160 hp O-320 engine.
    Tim's Avatar
    Petersburgh, NY
    3,452
    It's about time
    bigrock's Avatar
    Henderson, Texas
    284
    So what are the advantages of this electronic ignition over what we have on our planes now.
    Feb 2004
    Mt.
    1,283
    What about prop starting ? I don't think I would ever run a ignition system on a off airport airplane that I couldn't prop start.
    Dave
    Tadpole's Avatar
    Jul 2007
    Peyton, CO
    291
    Quote Originally Posted by ag-pilot View Post
    Dave
    The Carbon Cub doesn't have any mags. It can be prop started, but it's a pain the butt.
    8,860
    Sure looks like a lot of different parts which need to be mounted somewhere. That looks like only one system so that means double what is shown in Steve;s picture. There is not much spare space between the engine and firewall on a Cub.
    Jun 2004
    3,255
    In Tool Time Tim's system you keep a single mechanical mag with impulse coupling. He has fuel burns side by side with my dual mechanical mags where he burns at least 10% less fuel when we used to be the same.
    18,286
    This system is certified to run along side a standard magneto, preferably with an impulse so starting would not be effected.
    The main advantage is variable timing which makes the engine more efficient thus a reduction in fuel burn. Hopefully Michael from Electroair will chime in here.
    18,286
    Lots of good questions with answers on the system here. http://www.electroair.net/index.php/faqs.html
    10,034
    my question is sorta answered in #1 in the FAQ you post.....
    not sure how to word this...
    but in my mind, just using one mag option, the variable timing would be like running on one plug per cyl, since only the one plug on the new mag is lighting off earlier in each cylinder..?? party is over(already ignited) in that cyl by time the old mag fires at 25?????
    edit: which brings up another thought, so if you only have one of these wouldn't you want it set up to be all top or all bottom plugs for smoothness of the firing?? which would be better?(would be a pain? to do since most of our harnesses are top one side bottom the other..) hmmm maybe they do this already in #9 of the FAQ
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,286
    I don't trust computers...
    btracy's Avatar
    Apr 2004
    Ohio
    1,001
    Whats the weight difference?
    18,286
    LOL I can tell.
    sjohnson's Avatar
    Boise, ID
    615
    After reading the CAFE reports available on the website, I don't see how this system will help us in Cubs much. There is significant improvement at high altitudes and significantly lean of peak mixtures, which requires fuel injection. This is great for efficiency and just what the CAFE folks are interested in.
    But, must of us are in carbureted Cubs flying below 10,000 feet and generally operating rich of peak. The standard dual Bendix mags in the reports work fine in this regime, and just as well if not better than the mixed electronic and magneto ignition setup. I assume Slick mags work about the same.
    It appears we'd be better off working on better fuel distribution and atomization at partial throttle settings. Any ideas how to do this, and how to measure the results?
    btracy: there is no significant weight difference using the mixed system, 1 electronic and 1 magneto, which doesn't require a backup battery.
    nightflyer's Avatar
    Jan 2012
    Colleyville, TX
    73
    Since this thread was originally from 2011, what is the verdict on the Electroair electronic ignition system in Cubs? For you guys that have this system, do you like it and would you recommend it? Thanks!
    Oct 2002
    Stevensville Mt
    119
    Just my 2 cents worth, I have installed 2 of these 1 in a C-185 and the other in a High country Explorer. Both customers agree there is less fuel burn with the same power settings. Smoother running engines, Cleaner exhaust.The nice feature is that it adjust timing to manifold pressure. The 1 mag which is impulse aids in starting after that its useless by the time it fires theres nothing for it to burn.The spark is a lot hotter from the Elctroair, the spark plug gap is
    twice what the standard normally is. I think its a great step forward.
    RaisedByWolves's Avatar
    Feb 2005
    3,679
    Check with Bill Tracy, he put it in his cub. He has had some problems with it.
  1. Lghtspeed Electronic Ignition
    By snowyriver in forum Experimental Cubs
    Last Post: 12-28-2009, 08:08 AM
  2. Anyone using an E-MAG electronic ignition?
    By Speedo in forum Super Cub Sick Bay
    Last Post: 07-16-2009, 01:24 PM
  3. plasma ignition system 111
    By dynoluc in forum Experimental Cubs
    Last Post: 05-24-2009, 01:41 AM
