I need some advice on building a sod runway. The plan is place a grass landing surface next to an existing hard surface strip , It will be between 1200 and 1500 ft in length , 50 ft wide and at a privately owned field near Atlanta . It will have a slight slope from one end to the other but will need to be sloped in width to allow for drainage . What degree of slope from side to side would be best that would provide for runoff but not present a problem for directional control on landing ? Also , What would be the best type of grass to plant here in the SE .? I do not believe that crowning the surface will work because of the proximity to the existing runway . It will have to be sloped away from that surface..... Thanks ... RC
