Mike Vivion and others strongly suggested, in this thread and in pm's, to put on 1/4" plastic bottoms. Steve Eaton, thanks for doing the calculations...I didn't because it didn't feel much heavier, frankly, between the 1/4" and the plastic we replaced. We will know the answer when we do the final weight calculations, but I really don't think each ski bottom weighed much over 7 lbs each. Knowing Darrel and Bob, they will read this thread and do the numbers tomorrow, and we will get back to you. One of the reasons for reworking the ski bottoms was the finding of significant breaks/cracks in the old ski bottoms. The idea of a tougher, thicker bottom is appealing, as Steve Eaton pointed out, for some of the stuff we land on around here.
The 1/4" was really easy to work with. Easy to cut, easy to bend. Darrel will be taking photos of the project and posting them here, soon. We followed a number of peoples suggestions and used strips of the 1/4" plastic instead of the aluminum skid strips, to reduce the "stickiness" of the skis.
