Dears,
My name is Roberto and I'm writing from Brazil. I'm new in the SuperCub builders group. At this moment I'm restoring a Piper PA-11 Experimental aircraft at my hangar. I have some doubts as described below:
1. Where is the static port for the instruments? I will start covering the fuselagem in few days and I need to guide the tube, if it was the case.
2. Where can I find the Ilustrated Parts Catalog and Service Manual for that aircraft?
3. The aircraft is equipped with a Lycoming O-320-A2B (150 Hp). My engine mount is made by stainless steel and some tubes in front of the aircraft are aslo made with the same material to reinforce the structure at that place. Do you have something against this process?
Those are my doubts for while.
Thanks a lot for your help!
My Best Regards,
Roberto Serrano
www.kraussaero.com.br
Atenciosamente,
Serrano, Roberto B. - M.Sc.
contato@kraussaero.com.br
krauss@kraussaero.com.br
Cel.: + 55 35 8403 9778 (CLARO)
Cel.: + 55 35 9166 2954 (TIM)
Cel.: + 55 35 9935 2714 (VIVO)
