Bill Rusk
BENEFACTOR
Sandpoint, Idaho
Folks
In the process of the annual/rebuild I completely disassembled the airplane. The tail was removed, wings taken off, all interior removed, all controls, floorboards, etc removed. I went about as far as I could go without ripping the fabric off. I have been really surprised at how clean it is and how good of shape it is in. I have not found any dead fish or minnows. LOL
Very little corrosion or rust. Probably no more than would be normal. The Cub has 325 hours on it and they have been pretty hard hours. It has been rained on a LOT, hailed on, snowed on, been on floats, in Idaho, and generally run hard. Often full of camping gear and often with a passenger. I am pleased. But I wanted to inspect, lubricate, adjust and in general go over it very carefully before heading North again.
A list of some of the things done would be.......
Removed and cleaned under floorboards
Cleaned floorboards - no problems with delamination or water absorption
Removed torque tube - cleaned and lubricated and reinstalled
Lubricated all elevator, and rudder cables
Removed, cleaned, inspected, and reinstalled brake master cyls
Removed rudder pedals, and brake arms, inspected, cleaned and lubed all saddles - reinstalled - adjusted return springs for freedom of movement
Removed all pulleys, inspected, lubed and reinstalled - dang there are a lot of cotter pins in there
Fixed a tight left rudder pedal cable attach bracket
Cleaned tail surfaces, cleaned and lubed all clevis pins - ......more cotter pins
Replaced 3 tail VG's knocked off in helicopter lift out
Installed a new and improved ELT ground plane - tested ELT
Updated 406 contact info page with NOAA
Removed horizontal stab through tubes, cleaned, inspected, lubed, reinstalled with new hardware
Cleaned, lubed, inspected tail brace wires
Removed the Princeton Fuel Probe system - this did not work well. The tanks are too shallow for the probes to give accurate info - saved 12 oz
Adjusted the electric trim down stop. added another 1/4 travel or so
Replaced the Ztron labs master relay. Unfortunately it was leaking a small amount of current draining the battery. Also, unfortunately, it is no longer being produced. Too bad, it was excellent. Not enough sales volume. Std master relay added one pound and one amp. SUCKS
Adjusted throttle tension to prevent creeping
Removed manifold pressure gage and sending unit. Just not used with a fixed pitch prop. Saved 4.25 oz
Removed 8 amp alternator and install 20 amp unit. Redid a LOT of the wiring
Installed fuel pod, and installed pump, plumbing, fittings, wiring, toggle switch, fuse etc. Tested for function
Installed new door and window seals since I fly in the rain a lot. Gotta be tight
Installed wig-wag landing lights in wing leading edges
Installed and painted new headliner
Built a whole new cowling, painted, etc
Fabricated and installed a plenum for the engine
ETC ETC ETC
New headliner going in. Tried it again, still don't like Stewarts glue
New headliner in and painted
Made this "T" shaped brace to attach the plenum to. That way it is in two pieces and can be installed and removed without taking the cowl brace rails out. Used the baffling that was already there. The plenum should help with cooling but just as important (at least to me) it will reduce the stress and "working" of the cowling making it last longer and look better. I have not weighed it yet. I will report when I am finished as to its function and weight. The center bracket was made from .025 riveted together. The tops are .020
Right side of plenum
If you don't have one of these rivet drill jig tools, GET ONE, its the best thing ever!!
This is the little cowl brace that attaches to the cowl brace channel and holds the channel up and in position. Hint....run a tap (say 10-32) in the hole and it will make removal and reinstall of the rails a LOT faster and easier when you are building and taking them on and off every 15 minutes. When you assemble for the last time use a longer screw and add a nut just to make sure. When the tube is flattened there is more than enough thickness there to run a tap in. Really Really helps make life easier.
More to come.....Hope it helps
ETC ETC ETC
