Page 9 of 16 FirstFirst ... 7891011 ... LastLast
Results 321 to 360 of 616
Thread: Building a Javron Cub
  1. #321
    Found a couple of photos of the perfect windshield installation. Builder unknown. Sorry bout that. I would prefer to give credit to this high level of craftsmanship but perhaps someone else from the Boise area will help me here.
    OK so back to the real world. What us amateurs can do. A note or two to supplement the video. When you first rivet the inner strip on you will later be drilling those rivets out to remove the strip for trimming etc. Be sure to use an Aluminum pull rivet with an aluminum post. If you use an aluminum rivet with a steel post it will be a lot harder to drill out. Here my friend Jim is helping me rivet the trim strip on..............
    And here is the inner windshield strip pop riveted on...........
    This may be a little out of sequence but here is a photo of the side nut plates. Note the use of the different nut plate on the bottom to get the nut closer to the edge. Some folks use 5 screws on the sides but I feel 4 is just fine. Homebuilders as a rule, and I am guilty too, usually use too many fasteners.
    And finally a picture of how it all pretty much comes out.........
    Hope this helps
    Very Blessed.
  2. #322
    don't drill holes in plexi.. ( I used to always use unibits with good results.. heated by drilling a few holes in a block of wood first...)
    been over a decade since some on showed me a much safer way.....
    use the back end of an acid brush heated with a torch, to cut/melt through by hand.... never a cracking issue then, and if you need to move a hole a smidgen you can....
  3. #323
    Thanks Mike. That folks is a better idea folks from someone with a lot more experience.
    So here is a trick for the torque tube saddles.
    Take your basic screw driver with a round shaft.......
    Wrap it with a piece of scotch bright. Just 1 layer.
    Tape it on...........
    Now wrap it with a piece of 320 grit sandpaper, (we will then go to 600, and finish with 1000 grit) and tape it on. Catch the top of the screw driver with the tape. This will keep it from rotating.
    Chuck the screw driver up in your drill.........
    And use this to polish your torque saddles. 320, followed by 600 and then something like 1000 grit will give a nice finish. You should not have any resistance in your controls.
    I had some binding so I kept looking for the pressure point. I found the forward saddle was just a little too wide. Probably just excess paint. I used a die grinder like this to take just a little material off the front end.
    Seriously folks. Don't settle for ANY binding in your controls. It will only get worse. They should be almost sloppy loose. There will be plenty of friction due to cable friction, pulley angles, air loads and just general Murphy's law. Work on em til they work perfect.
    Hope this helps.
    Very Blessed.
  4. #324
    Great ideas Bill. Nice work too. I need to drill my boot cowl and windshield. I have been putting this off as I am a little apprehensive, and worried of making a permament error. I have seen that reference video before. Darrel Starr sent it to me. Those guys make it look so easy, just like the guys who restore a car on TV in a 30 minute episide. In my opinion, the windshield gap inside the inner/outer strips needs to sit perfectly for a nice, quality finish...another trademark of a superior restoration. This is what has made me so apprehensive. I will watch the video again. The techniques should be the same for installing in the -12 from what I can tell. Keep up the good work!
  5. #325
    Or you can lay it up in fiberglass like this. I did this in a couple of hours. It fits perfect and is smooth with no dimples where the screws hold it down. Don
  6. #326
    I used a small electric soldering iron to do my plexy holes. Worked a treat.
    Back Country O-375 wide body extended wing cub
  7. #327
    Quote Originally Posted by pittsdriver View Post
    Don, would you mind explaining how to do that? I've very little fiberglass experience, and that looks really nice. I struggled for hours and hours to get my PMA'd windshield strips to fit. Got them "pretty good", but not like that!
    Gordon N4328M
  8. #328
    Quote Originally Posted by 12 Geezer View Post
    It's a lot easier to show someone how to do glass layups than to write instructions. I might have to start a thread on glassing. I started making surfboards when I was 12 and did RC scale models that were glassed then a Lancair 360 and on and on. I have to be very careful as I get a bad reaction from a lot of epoxy's. Don
  9. #329
    Sidebar
    I had to take a some time off the Cub to do a little work on the Hatz. I decided to do a top overhaul after last season so this spring I tore into my back up core Warner Super Scarab 145hp engine (same type engine currently on the Hatz) and started to get all the top end parts ready. I had the cyls rebored and chromed with the nu chrome process, new rings, pistons cleaned and checked, heads cleaned and welded a couple of cracks, new guides, seats checked - ground or replaced as necessary, valves checked and polished, etc.
    Bobby Breeden was the last one to get a ride. I took the top end off last night.........
    After a long, late evening tearing it apart I had Dick Weeden, an "old engine" expert, machinist, and mechanic that rebuilds Warners, LeBlonds, Kinners, Szekeley, Lenapes, etc come over to the house and inspect the bottom end. He declared it good and tight so now I can install the new top end and have a fresh engine. Cool Beans. So a little side track from the Cub that, Lord willing, won't go too far astray. Hopefully I will have the Hatz at New Holstein and can give some rides. Dick is a great guy, very nice, and very knowledgeable. I am fortunate to have him as a resource.
    Very Blessed.
  10. #330
    Very cool Bill! I sure love that airplane!
  11. #331
    Going back together. The heads fit onto the Cyl barrels with a tight press fit. I am still working on getting everything back together but I learned a few things today I thought I'd share. When heating the head the expansion is pretty linear. It expands about .004 per 50 degrees until 400 degrees. From 400 to 450 degrees it only expanded about .003 and about the same between 450 and 500 degrees. The powder coat finish held up just fine at 500 degrees. Total expansion was from 4.848 to 4.872 or about .024 thousands. Putting the cyl in the freezer only reduced its diameter by (at the most) .002
    Very Blessed.
  12. #332
    Yup, aluminum has a greater coefficient of thermal expansion than steel. Looking up the numbers, I see that alum is about 12 micro-inches per inch per deg F, and steel is about 7. http://www.engineeringtoolbox.com/li...ents-d_95.html
    Sweet looking airplane, Bill!!
    Gordon N4328M
  13. #333
    I think if you can engineer a Rotec radial and sell 'em you ought to be able to reverse engineer a Warner and build them again. To me it's about the coolest radial engine going for a small airplane. Those new radials don't sound like a radial. For many years I shared a hangar with Harold Newman and propped his 145 on his Monocoupe. That was a treat for me.
  14. #334
    Had to take the Warner heads to the machine shop for a little tweeking so went back to the Cub for a day or two.
    I really liked the thread on removing the triangle shaped left side window so I jumped in with both feet. Here is a before shot (well, actually I had started cutting on the bottom channel as you can see)........
    And after cutting the post and bottom channel out, (I placed a piece of channel on the bottom part to see what it would look like)..............
    I will get some of the appropriate stock from Jay, weld it in, (lest folks think I know more than I do and that they could never build a Cub because they do not know how to weld....I will have someone else do the welding) touch up the paint and have a cool mod that I did not know about before.
    MMR came by and I put him to work cutting plexiglass.........
    Mark has been a great friend and really helpful. Very meticulous.
    More in a moment
    Very Blessed.
  15. #335
    Weight Savings
    I do not have firm data on all of these items but I thought I would share a few things I have done to help keep the weight down on this build. Many of these are in relation to my last Smithcub project.
    Fuselage - I am fairly sure that my current 105 pd fuselage is lighter than my last one but unfortunately I do not have a weight from my last one so I can't quantify this one. It is a narrow body and much effort was placed on watching the weight. My guess is a min of 10 pds lighter and it may be more.
    P-mags - 6pds lighter than my last Bendix mags (3 pounds lighter than Slicks)
    Titanium Firewall - 2 pounds
    Ztron Master Relay - .5 pounds
    Alternator - at least 3 pounds but not really sure. Using B&C 8 amp. No belt, no mounting brackets and lighter Alt itself 2.5 Vs 5
    Flywheel - 3.75 pds
    Spinner - 1.8 pds (will use skullcap Vs full size unit)
    Boot cowl - 2pds - factory = .020, used .032 last time, used 2024-T3 .020 this time (Calculated not weighed)
    Main cowl - 3 to 5 pds?? see above,.... last kit was .032. I will go back towards factory and/or some CF
    Sub Boot cowl - 1.5 pds - I will not use the metal behind the boot cowl. The fabric will go up to the boot cowl.
    Built in thrustline - 1pd? not sure here, I will also not have a swing out mount. Together it may equal 1.5 pds
    Firewall Blanket - 3 pds Last build I used a "Koolmat Heat Barrier" blanket from Spruce # 09-24730. It was nice but HEAVY. This
    time "Thermo Guard FR" Spruce # 08-01029. Much better.
    Engine itself + 10 pds depends on your starting value. As best I can tell my 0-360 weighs very close to my last 0-320 but I'll say I
    added 10 pounds. If you do not pay attention here it can cost you a bunch. I am close to 20 pounds lighter than
    many other 0-360 models and may very well be close to0-320 weights
    Drilled brake rotors - .5 pds
    Long Step - 1.5 pds Javron step Vs Atlee Dodge unit
    Bungees Vs die springs - 2.5 pds
    Interior - 5pds. Using more CF this time and less fabric covering.
    Avionics - I think I may be able to get 4 or 5 pounds out of the panel
    Wings - 20pds (may be more, unfortunately I have no wing weight from last kit) lighter ribs and going to 18 gal tanks Vs 24 on
    last one.
    ELT - 1.5 pds
    Tail Feathers - 6 pds (known weighed value)
    Trim system - .5 (no indicator this time, will use the painted mark AKA Cub Crafters)
    Half Skylight - 1.5 pds ( known weighed value)
    Landing lights - 2 to 3 pds I will be using LED lights mounted in the nosebowl, eliminates the heavy wing mount assembly, wires,
    plexiglass cover, etc.
    Hope this helps
    Very Blessed.
  16. #336
    Thats 85lbs. Would you have a picture of jays step?
  17. #337
    See page 4 of this thread.
    Very Blessed.
  18. #338
    Bill you need to change you avatar and log-in name to Nutplate
  19. #339
    Here is a step we had machined for the Warbug Cub. It also has a threaded end for a shovel head. Has the same lugs in the gear like Bill's. I don't know how much it weighs but it is light. On the other side is an axe that doubles as a step to check fuel. Also went with the swing up left window but the drawback to that is you either have no air or a bunch of air. I think I would go back to the stock sliding window on the next one. Don
    Vans RV7 finished 2008
    Backcountry Super Cub finished 2011
  20. #340
    Slowly going back together. Possible test run tomorrow. Been getting a lot of help from my friends, Jim and Tom. BIG THANK YOU guys.
    Very Blessed.
  21. #341
    ....It also has a threaded end for a shovel head.
    On the other side is an axe that doubles as a step to check fuel. ..... Don
    I like the dual purpose/eliminating carrying a separate Item ideas!
  22. #342
    She started on the first flip today. No matter how many engines you build it still feels great to hear it run for the first time. Hopefully the rest of the break-in will go well and I can get back to working on the Cub once again. Again, many Thanks to Jim for all his help.
    Jim sitting in cockpit.
    Very Blessed.
  23. #343
    Bill, yaHOOO! on the Warner/Hatz startup. Thanks for sharing the great news. And I'm remiss in not saying thanks sooner for your gracious hospitality and tour last weekend--very impressive stuff all around your hangar/shop, and I especially appreciate you posting updates on this forum.
    By chance, I ran into J.D. at the fuel pumps, who knew of your Hatz, since he's building one; I think we'll be at the same breakfast run tomorrow.
    Keep up the positive good news.
    Thanks. cubscout
  24. #344
    Way to go guys, that Hatz looks and sounds terrific. Another project done! I see you are utilizing your time off in a great way. Can't wait to fly in it again.
    David
    David Childs
    "Whether you think you can or whether you think you can't, you're right!"
    Henry Ford
  25. #345
    Good Job Bill and Jim. I know a place you can land in Oklahoma if you and Jim need a break-in trip this summer. Awesome Plane. Greg
  26. #346
    Love the sound of the radial!
    I am just lurking watching your build and enjoying the pictures---Keep it up Bill ------thanks----tom
  27. #347
    Thanks for all the support guys. Unfortunately on the second run, I found a cyl that was leaking around the cyl to head joint. Turns out there were two very small cracks at the head stud bases that allowed these studs to loosen out. That head will be very difficult to fix so I am scrambling to get another head together and installed. The good news is all the rest of it seems most excellent.
    Still hoping to get it to NH.
    Very Blessed.
  28. #348
    Can I get a ride on Wed night
  29. #349
    Glenn are you flying out with us?
    P.s. bill your doing an awesome job with the write ups. I love all the detailed pictures.
    Tom Ford
  30. #350
    Glen - Yes. You are officially on the list.
    Many Cudos to Brian and the guys at Poplar Grove Airmotive. I took a head to the shop at 0810 Friday morning and in one day they cleaned it, checked it for cracks, powder coated it, did all the valves, seats, guides, etc and got it back to me at 1530. That is WAY cool. Great job guys!!
    MMR and I put it back together today (while Jim worked on the Cub) and I got in a test hop this afternoon. Ran great. No problems that we could see. I will try to get some break-in time on it in the next few days and, if all goes well, it will be at NH.
    Very Blessed.
  31. #351
    I've heard nothing but good things about Poplar Grove Airmotive. If I ever find a suitable 90 horse PA18 to buy (soon, I hope!), I'll be sending it over there if it ever needs engine work (never, I hope!)
  32. #352
    Hatz - I have about 2.5 hours running it hard to get the rings to seat and so far so good. I will try to do some more this weekend.
    Jim was working on my seat while MMR and I were working on the Hatz. So here is a little detail on the seats. I ordered the Confor (temper Foam) from www.seatfoam.com in the soft and firm pads. This results in a comfortable seat that is not "too" heavy. Standard foam will work but only for a little over an hour then you will get a sore rump. Each layer is about 1 inch thick so I put the soft foam on top and the firm on the bottom for a 2 inch thick seat bottom. I use the lighter standard foam for the seat backs and that seems to work fine. I'll try to provide a little more data on all this when the seats are actually sewn up.
    I like the simple clean look so I do not have a pocket on the back of the front seat. I place a piece of the Honeycomb composite material inside the sewn cushion and then screw it to the seat frame. To do that I use nut plates turned inwards so that there is as little protrusion into the seat as possible. These nutplates are riveted to the seat back and bottom with aluminum reinforcements. It all looks like this.......
    Seat back being held on with 4 screws and nutplates.
    Note the screw into the back.
    Seat bottom.
    Close up of the nut plate inverted and the reinforcement plate. Screws will be sized at the end so they do not protrude above the nut plate.
    In this photo you can see the screw and both reinforcement plates. The composite board will be inside the seat upholstry so that all you will see when it is done are the 4 screw heads. Very clean and tight. There may also be a photo or two on the last thread "Building a Smithcub" (Jim does great work, Thank you)
    More to follow
    Very Blessed.
  33. #353
    Don't forget to add a lumbar build out with the firmer foam.
    Lou
  34. #354
    Just curious - was that Mehlin Smiths Hatz?
  35. #355
    JL - Yes. It was built by Dr Mehlin Smith. I have been fortunate to fly it from the beginning and now own it. Mehlin Passed away suddenly and unexpectedly last Oct. He was a good friend and is/will be missed.
    Thanks Lou
    Fuel lines. Here are some photos of my fuel lines. These are roughed in and will be secured to prevent chaffing, but it will give you some idea of routing. Note the right rear line may actually show slightly under the fabric on the outside at the wing to fuselage junction. I will have a fabric headliner and this will be the least noticeable positioning. I used the fuel valve part #6749 from Aircraft Spruce. I drilled out an additional port so I can have a "both" position. This is well detailed in the Backcountry Builders Manual. These are 3/8 lines. Note that all the lines run downhill all the way. I do not like having ANY fuel line going uphill. Also note there is only one connector (other than at the valve). Each connector is a potential leak point and also a possible flow restrictor. The fewer connections you can have the better off you will be. You may have to re-make the lines several times to get them all bent properly so you can do it without a bunch of splices.
    This is the fuel valve with connection hardware. Total weight is 8.51oz. There are more sophisticated fuel valves that cost 250 to 450 dollars. This one works just fine and cost 25 dollars. It is quite common in the RV community and has few complaints. Your choice.
    I like to use this fuel lube. It is also a sealant. You can see where I have smeared some on the threads of the connector. Keep it out of the line and use it on all your fuel connections and you will probably not have any leaks. Works great.
    Note that no line runs uphill and also that three of the four lines have no joints. Thy go straight into the valve. The right rear is a really long line and it is two piece with one connector as you will see in a following photo.
    This shows the top of the right front line. You want all your tops to be as low as possible once above the structure in the wing root area. You can also see the top of the left front line in the background.
    More right front routing.
    End of right front routing. Also note the bottom of the left front routing. The top part of the left front line just runs up the channel like the right front.
    This may not be the best photo, but I like to run the left rear line right in the gap between the window channel and the back vertical post. I epoxy it in place and after paint it is almost invisible except to a cub guy who knows what to look for.
    This is the front of the right rear line. Note it is outside the structure. This would not be necessary if you are going to use a metal headliner. I am doing it because of my intention to use a fabric headliner.
    More of the right rear line.
    This routing is again dictated by my headliner choice. There will be a slight bulge in the headliner fabric just behind the window for a few inches where it transitions down behind the interior panel. Best I could come up with given the circumstances.
    Total weight of all the lines with AN hardware is 23.55 oz and with the valve, the total fuel line system weighs 32.06oz. Cub Crafters is using a nylon type of fuel tubing. There may be some weight savings there.
    Folks - this is just my way (and certainly not the only way, or even probably the best way). Your circumstances may dictate a different set of lines, valves, routing etc. But I hope this helps someone.
    Very Blessed.
  36. #356
    Thats almost just like the CC headerless system. They put rubber line splices in the long runs to mitigate cracks.
    With guns, we are 'citizens'. Without them, we are 'subjects'.
    "To be born free is an accident. To live free is a privilege. To die free is a responsibility."
    --- Brig. Gen. Robby Risner
  37. #357
    Well, at the three hour point for the new Hatz motor, with everything running great, I did a thorough check to include timing the mags, checking all valve clearances, changing oil, checking cylinder base nut torques, compression check..............oh boy, found a low one.....found a crack at the spark plug hole. So, I will be at NH but not in the Hatz. I can fix it but not in the time frame I have left before the show. Looking forward to seeing all my fellow SC.org friends there. Back to the Cub.
    Very Blessed.
  38. #358
    Seats
    After a little diversion fooling with the Hatz I did have a little time to fool with the Cub seats a little more and I said I would provide more info so here it is.
    This is a picture of the tan colored foam that is readily available from craft stores, upholstery shops, etc. It is available in different densities and thicknesses. I used 1/2 inch firm on the bottom and 1 inch thick medium density on both the seat backs and the seat bottoms of my last Cub. Unfortunately the seat bottoms became uncomfortable after about 1.5 hours. The backs were just fine. This foam material is about 1/2 the weight of the good tempurfoam/Confor foam. The front seat bottom tan foam, firm, weighs 4.84oz. The 1 inch med density foam weighs 5.91oz so the total foam for the front seat bottom weighs 10.75oz. The good Confor foam is 1 inch thick and I used a layer of firm and a layer of soft. So the thickness is 2" thick Vs the Tan foam that would be 1.5 inches thick. The Green color is the firm density and it weighs 11.88oz and the pink, soft, weighs 11.0oz for a total foam weight here of 22.88oz so as you can see the Tan stuff is just about 1/2 the weight of the good foam. Bottom line. Use the good stuff for the bottom but the lighter Tan stuff will work just fine for the seat back and it will save you some weight. Since the back seat is about twice the size of the front seat your total weight savings would be close to 2 pounds by not using the good (but heavy) foam for the seat back. Further you could also use the three density good foam to build a seat like Oregon aero and it would be three inches thick. I don't think it is necessary as, after I remade my seats using just the two layers, firm and soft, I thought my seats were very comfortable even to the point of a thirteen hour (in the air) day.
    This is a picture of the confor foam. The green color is the firm and the pink is the soft. They do make a medium density as well if you wanted to do a three ply seat.
    This is a picture of how things go together. The honeycomb base goes in the seat cover, then the dense foam, and then the soft foam on top. Again this would be for the seat backs. For the bottoms you would use the better foam. Also note that we put zippers in the seat covers so that they could be taken apart for cleaning. These zippers were on the left (throttle) side of the seat so they could not be seen.
    Here it is all zipped up together
    The seat bottom is then screwed on like this...................
    Makes for a very clean, crisp, seat job.
    This is what the back seat will look like starting out. When I did my last one (and I'm doing on this one) I made the rear seat back like the front seat, with the board inside the seat cover. However for the rear seat bottom, I left the board out of the cover. I placed a couple of snaps on a finger tab so that the cushion could be snapped down onto the seat bottom board. This allowed me to easily remove that cushion and use it around camp as a cushion, pillow, or whatever I needed it for. Since it did not have a board zipped inside it was soft and pliable. Not a really big deal but it does allow you to get more uses out of that cushion. There are ways to do that for all your seat cushions if you want but the installation may not look as sharp. It's all a trade off.
    This is a picture of the rear seat bottom snap installation/technique. The snap is just folded under the cushion and snapped down. It does not hold it down really tight but you don't need for this one to be rigidly tight. This just keeps the wind from lifting it up when flying with the door and window open.
    I hope this makes sense and is usable info for folks thinking about how to do your seats.
    Very Blessed.
  39. #359
    Looking at the composite board you are using for the seat and baggage floors. There is a nice easy and light way to finish the edges . This will also seal the edges from any liquids soaking in , like water or fuel .
    You can undercut the core only from the edge about 1/4 inch deep . Leave the outer layers of glass . Mix up some resin with micro ballons , fill in the edge . When cured , just lightly sand the edges to finish.
    You can also do this to reinforce holes cut inside the board, such as lightening holes , and to reinforce drilled holes where you will put bolts thru . This will keep the board from crushing as you tighten the bolts. We use flox with the resin in these areas , it has more structural strength .
    You can make a simple steel tool to scrape out the core material or a small grinding wheel on an air dremmel .
    We do this all the time on composite aircraft.
  40. #360
    Bill,
    What do you think about the 1.6 lbs composite
    tailwheel spring that just got approved on the Husky?
    Dave
  1. Building Fin
    Last Post: 06-01-2009, 06:15 AM
