Results 1 to 9 of 9
Thread: Tach cable. Long turn or no long turn.
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,016
    I had my tach cable go out last week while I was in the middle of doing a float rating... Bad news. But we managed to get it up and going after a day.
    Now I have a fairly long cable that makes a big sweeping turn under the panel and enters the tach via a 90 degree angle drive unit.
    One AI told me that I should have the long sweeping turn and another told me that I should get a shorter cable and try to go as direct as possible.
    Which is correct?
    May 2006
    3,019
    I'd go with "Another" ... Ask "One" why he likes a too-long cable.
    Sep 2004
    Illinois & Wisconsin
    562
    Ditch the cable and get an electronic unit.
    behindpropellers's Avatar
    NE Ohio
    6,637
    The 90 degree turn adapter reverses the direction of the cable, so it is essential. Sweeping turns are good, really doesn't matter on the length as long as it works correctly.
    Mush's Avatar
    Nov 2007
    Talkeetna, AK
    209
    It's not a bad idea to shoot the prop with an optical RPM sensor as well. I have seen where a small bend can cause as much as a 100rpm reduction. They had the cable shortened so it was straight as possible and the reading was dead on.
    9,811
    Quote Originally Posted by Mush View Post
    .....I have seen where a small bend can cause as much as a 100rpm reduction. They had the cable shortened so it was straight as possible and the reading was dead on.
    how can that be true?????? unless it was slipping/spinning in fitting on engine end????
    or pushing at the tach and and somehow fuxing with the magic in it???
    9,811
    Which is correct?
    I always have reeve make them custom to the proper length when doing a panel/rebuild...... but no good reason other than doing the job and gonna do the best I can...
    anyway, most all go to the EI electric tach now at rebuild.....
    nd
    3,029
    I think Alex has a continental 4 banger in his craft.
    Alex Clark's Avatar
    Feb 2004
    Life Long Alaskan
    3,016
    Yeap C-90-8
    And for those who do not think it makes a difference, you can goof with the tach reading by moving around an unsecured cable while it is running. Strange but true.
    The cable is woven in a directional manner and will bind and release in litle spurts while rubbing against the cable housing.
    And those 90 degree drive units can either reverse the cable direction or keep it the same. You just pull out the little end unit and install it backwards top make the change.
    They are built that way.
  1. J-turn Takeoffs
    By Texas 12 driver in forum The Art and Science of Flying
    Last Post: 11-21-2009, 06:23 PM
  2. My turn in the barrel
    By SJ in forum Member to Member
    Last Post: 08-23-2009, 06:15 PM
  3. Turn the news on now
    By pzinck in forum Cafe Supercub
    Last Post: 09-27-2005, 04:14 PM
