I know that I have posted a thread about the GPU before but now I have a new question. I need some info and pictures of how the actual socket is attached to the battery shelf and the fuselage fabric. And how the socket supports the outer frame/door. I have drawn a diagram of how I think it should be but I can't figure how to make it happen. The socket does not have any screw holes in the flange to indicate that the outer frame/door was screwed to the socket assembly.
So--how was the outer door/frame assembly attached to the fuselage???
What keeps the outer door from falling in to the fuselage (there are no stops to keep the outer door aligned with the frame)
The outer door has a buttom that has to be pressed in order to open the door--but you have to press pretty hard to make it work--if that door frame is not attached to something substantial then you may rip the fabric when it is pressed!!!
Someone told me that there is supposed to be a plastic frame that fits behind the outer door/frame with the fabric between the two and the outer frame is screwed to the inner plastic frame--but that does not seem strange enough.
I have attached some pictures that I hope will help to answer my questions.
