Darrel Starr
Plymouth, MN
I like the Leading Edge exhaust system on N18SY except for one thing. When I am coming down final, I often get an exhaust smell in the cabin. This seems to happen only when the plane is slowed up and the wing is at a relatively high angle of attack with no crosswind. Exhaust then seems to swirl around and come in the gaps surrounding the door, probably the lower door. Does anyone else with this exhaust system have a similar issue? Has anyone tried a longer exit pipe? I was thinking of having one made up that is about 2 inches longer with a straight cut on the outlet, not the extreme angled cut on the outlet opening that comes from the factory. I tried emailing Leading Edge on this issue but got no reply. The Sutton exhaust seems to have a much longer pipe.
Thanks, Darrel
Thanks, Darrel
