As I said in the original post with the exception of using my turbine HVLP system and mixing by volume (Described in the instructions) I did follow the directions. I shouldn't have to spend hundreds of dollars to buy a compressor driven system and Delvillbiss gun to shoot a particular paint. Considering I have been able to fine tune the turbine to get excellent results with other products, I thought that I would be able to do the same with the Stewarts, (Case in point the post about using a Wagner sprayer).
I just finished rolling the finish on for what ammounts to the eighth attempt with the highest quality foam roller and a technique that has yielded superior results in the past with other products, once again more orange peel. The problem is the paint has poor flow out and leveling properties as well as horrible covering characteristics, primer is still showing through, (Coverage has nothing to do with technique).
As far as slamming the Stewarts Systems products when you have invested as much money and time as I have for such poor results, I feel ripped off. I maintain my position that this paint and primer is very finicky to apply in all but a perfect and ideal conditions, (How often is the average person going to be able to obtain that).
