WindOnHisNose
BENEFACTOR
Lino Lakes MN (MY18)
I am experiencing major difficulty starting my PA18, most recently yesterday at Ely during the Fall Colors Tour. I am going to have a great engine shop look it over tomorrow, but would like any wisdom you might offer.
Here is a scenario that has happened beginning about a month ago (really no problems before that). When I pull the aircraft out of the hangar for the first flight I typically pull the throttle back, mixture full rich, pull and push the primer 3-4 full shots, lock in the primer, turn on the magnetos and ignition and within 4-6 turns of the blades the engine fires right up. No problem. (My starter switch is one of those keyed type with which the first click is one mag, the next is the other, the next is both, the next engages the starter). I burn 100LL. The engine runs up nicely, both right and left mags have only a small drop (50-100 rpm), the carb heat check pulls down rpm (even as much as 400 rpm), full power is applied smoothly and the engine runs great.
Upon landing I typically lean the mixture while taxiing to parking, and upon reaching the parking spot I pull the mixture to full lean, the engine promptly shuts down, I turn off the mags and the electrical system, get out of the plane.
If I get back in the plane shortly thereafter (30-45 minutes) I do the hot start procedure I have always used: throttle cracked 1/2 inch, mixture full rich, NO PRIMER, engage the starter and the prop turns over, and over, and over, and over....no start. So I figure it must be flooded, so I pull mixture to full lean, throttle full forward and crank it several times. Stop cranking, pull throttle back to 1/2 inch open, mixture full rich, crank it over and over (once in awhile it fires, but doesn't start). I repeated this ad nauseum until good ole Pat Angelo comes to my rescue and points out that it may be flooded and he shows me how to clear a flooded engine by putting mixture to full lean, throttle full forward, mags off (duh), pull the prop backwards 10-20 times (I don't understand why this should help, but I've been told this helps by others, too) and sure enough fuel runs out onto the pavement for the first few turns. Then tried the mixture full lean, throttle full forward, crank a number of times, then mixture full rich, throttle cracked and....crank and crank and crank. No start. We tried this until the battery was wearing down and we were tired of turning the prop backwards.
I should also mention that Pat slowly turned the prop to listen for the clicking of the impulse coupler, and we heard it click nicely.
I asked Pat to leave me there, go on to Anderson's (which he reluctantly did), and it was my plan to let the plane sit in the cool air and try to start it when it was cooled down. Hooked a jumper battery to the aircraft about an hour later, tried the start using full rich, cracked throttle, no prime and it fired right up! I called Pat to tell him the good news, I battened things up (wheels were chocked) and flew back home.
I don't understand this at all. It seems as though it is flooded, but I don't understand how that could be after those attempts to clear a flooded engine. Anyone have suggestions/explanations?
I want this thing to start up easily to fly down to East TN in a couple of weeks and it is making me real nervous. Thanks.
Randy
Randy
