mike mcs repair
I needed a clamp to hold a cable so I could install a Nicopress. The available cable vises are very expensive and you need four hands to get everything aligned while holding the whole thing steady without the vise, so I made this out of some scrap 1/2" square tube brazed to a piece of 14 gauge strap, a 3/8" hardware store bolt and nut.
I used a chisel to form a small indent on the inside flat of the square tube to hold the cable. The bolt has a slight hollow in the end from the thread forming process. I only tighten it finger tight and it has seemed adequate to hold everything together while squeezing the clamp. The vise is a 2" Wilton.
There is a bit of room to put a tab or link in the eye also.
Wayne
I Like it! might have to make something like that.....
got me thinking now.... maybe based off a vise grip....
