no fancy jig needed for putting the twist in flaps and ailerons, and its guaranteed to match wing twist...just make sure WING twist is proper before doing this...
you do this before you rivet along spar(or remove rivets).. pictures were taking midway through project after some riveting was done...
simple just a bunch of strait sticks/bars, and some washers and bolts...
note there is a 3/16" space taped to striat edges, to help miss trailing edge skin/screws on wing and help lay flat on ribs.. also why there are 3 washer on top of strait edge, to make gap same...
