Results 1 to 28 of 28
Thread: Bushmaster on floats
    Aug 2010
    Yellowknife
    4
    Not sure if this is the right place to ask. Looking at a Bushmaster right now and a couple questions comes to mind...
    1) it is rigged up with edo's 2000. Is it not a bit underfloated for this plane? Anyone with a Bushmaster operating with these floats? How do they perform?
    2) It has only a 36 gallons tank which is small. What sort of mods is there for a larger fuel tank size? Belly mounted? wings?
    Otherwise looks spretty impressive to me...
    Cheers
    Tazin
    Dec 2008
    Nova Scotia
    815
    It would be under-floated with 2000s. A friend has his Bushmaster on 2440s with 180 Lycoming and is considering going to 2250s which I have on mine with same engine. I think 2250s are the real McCoy with 42 gallons and 84/43 prop. It's a real performer, compared to my SC 150 on 2000s.
    Aug 2010
    Yellowknife
    4
    floats
    The bushmaster I am looking at rigth now is actually a certified aircraft and is not in the O & M category so I am just wondering what stc's there are available for an upgrade for floats? Are the 2200 stc's?
    Cheers
    Tazin
    Dec 2008
    Nova Scotia
    815
    Aren't all Bushmasters experimental, Tazin? Many are as mine: stretched PA22 fuselage, extended tailfeathers, 180hp and longer props, including non-approved Lycoming 84/43, none of which fit the certified category. Floats are whatever is best for the mission. Regards, King
    Louis's Avatar
    129
    Turtlepack makes a decent alternative to extra fuel, skipping the need to the not so always available STC mod.
    Louis
    Mar 2010
    77
    saw a bushmaster 300 on trade a plane .com few weeks ago.
    What kind of performance would something like this have.
    Reuben
    Dec 2008
    Nova Scotia
    815
    Good question, Reuben. Depends on the mission, I guess. What's the load and range penalty with that heavier engine and fuel consumption? I can't speak for performance with a 500-pound overload but 180hp with 2250s does wonderfully and I wouldn't even go to 210hp because of fuel considerations.
    Aug 2010
    Tisdale, Saskatchewan, Canada
    1
    Bushmaster with 180 hp on amphibs
    I have just bought a BM that Milo DeAnglis built at Vernon, but it is not certified, although I understand many were. It had a leading edge cuff added, and a manual Ray Jay Turbocharger. The homebuilt floats are 25oo# so that should allow a 2880 gross weight or 1175 capacity. I am thinking of pitching the prop from 42" back to 44'.
    Does anyone have any advice? I do not need to jump out of the water in 200 feet, but do want to do some long distance cruising at alititude and cross the high Rockies. It has 60 US gal of fuel. It will need the fabric paint rejuvenated in a year or so.
    I plan on going to Yellowknife this fall or next summer from Saskatchewan.
    If you are passing through and want to stop for a night in Tisdale, Sk, give me a private message.
    shouldhunt's Avatar
    Sep 2006
    Chugiak, Ak
    74
    You can buy the STC for a certified bushmaster with a 180 hp, for like $2500. We have one at the shop, if you want the contact info, just drop me a line and we can dig it up. They are great planes.
    Terry, AKA cornbread
    Mar 2010
    77
    Re: Bushmaster on floats
    Quote Originally Posted by King Brown
    Well hauling heavy loads long ways. ( 2-3 people + baggage up to 300 miles or as mush gear as you can put in it for same distance).
    Reuben
    Dec 2008
    Nova Scotia
    815
    That's serious hauling compared to my two-person, fishing-hunting 100-mile flights, Reuben, a whole other thing. A friend tells me he's handicapped with 2440 floats with 180hp in his Bushmaster.
    Mar 2010
    77
    I guess it is more the kind of work that you use a 185 or helio for.
    What id the useful load on your bushmaster 180?
    Reuben
    Dec 2008
    Nova Scotia
    815
    Empty 1318, gross 2250, two persons, full fuel, 100 pounds baggage on 2250 floats. The 180 Lycoming is no handicap for small lakes and ponds for hunting and fishing.
    With extended tailfeathers, you're on step zip and off within 10 seconds. Needless to say, the registered GW is very modest with the Smith wing. Your missions are something else entirely.
    Mar 2010
    77
    What is the empty on wheels?
    Reuben
    Dec 2008
    Nova Scotia
    815
    bushmaster on floats
    Empty weight on wheels 1318, empty weight on floats 1537.
    Mar 2010
    77
    How would your bm 180 compare to a four place super cub with o-360?
    Reuben
    May 2006
    3,008
    I know a guy from south BC moving to north BC, & would like to have a BM.
    I know a lady who owns a BM whose initials are BM.
    Both factoids, no BM!
    Likes C-FIJK liked this post
    Aug 2010
    Yellowknife
    4
    Someone just mentioned to me that BM have a weak undercarriage (on wheels)? Any truth to that?
    Cheers
    Yakima
    145
    Super 20 gear
    If you use Eddy Trimmers Cub gear conversion the problem goes away. It can be seen on our latest A/C at www.shortwingsupercub.com
    Aug 2010
    Yellowknife
    4
    parts
    Are parts difficult to find for the Bushmaster?
    Dec 2008
    Nova Scotia
    815
    Tazin, a Bushmaster, experimental or certified, is a modified Piper PA-22 or Tri-Pacer. In experimental category, I stretched the fuselage by 27 inches and made larger tailfeathers, converted to conventional gear, larger 180hp engine and McCauley 84/43 prop. Parts are no problem: buy them or make them.
    Oct 2010
    Yukon/Northern Ontario
    3
    Bushmaster
    Hello,
    Long time lurker, first post. I am also in the market for a Bushmaster. Don,t mean to hijack the thread but thought it maybe be a good spot to exchange info. I am considering a BM from southen BC. I live in the Yukon and North Western Ontario. If you guys know of any for sale or can direct me to any good on line information etc. I would be very grateful. I,ll do the same. I wouldnt mind a mild project but dont want a full blwon rebuild or kit, or complete re-assembly. I am looking forward to the prospects.
    Cheers, Dog_River
    Haslett Mi
    9
    bushmaster
    well guys look at the classifieds on this site . I have a bushmaster project that I would let go for a real reasonable price.
    Dec 2008
    Nova Scotia
    815
    Why moving undercarriage forward, iceboat?
    Nov 2014
    Edmonton
    1
    Hello members, I am new to the site and its great to read your comments on the BM. My Uncle has been around BM for the better part of 20 years. He worked with Milo DeAngelis on many BM builds over the past years in the Okanagan. Currently my uncle lives and and works on BM out of Villeneuve, Alberta. He does not do email but you can contact me for further info if your interested. Thankyou
    sadams's Avatar
    May 2006
    Lopez Island, WA
    56
    Two of us are trying to assemble all the Bushmaster Drawings on a CD.
    We are missing SAC-2100 and SAC-2200 all sheets and SAC-2700 Sheets 2,3 and 4
    If you can help we will return your drawings and provide a CD.
    steph3339 at gmail dot com
    Steve
    C-FIJK's Avatar
    Jan 2005
    Lewisporte N.L.
    315
    The one your looking at is the only certified one in Canada , they have operated it for a few years now .
    Quote Originally Posted by tazin river View Post
    Cheers
    Tazin
    Gerry Marcil
    Every day spent flying is a great day !
    C-FIJK's Avatar
    Jan 2005
    Lewisporte N.L.
    315
    http://www.lespac.com/pincourt-monte...&requester=SCH
    Quote Originally Posted by Dog_River View Post
    Hello,
    Cheers, Dog_River
    Gerry Marcil
  1. Bushmaster
    By King Brown in forum Member to Member
    Last Post: 05-18-2010, 05:42 PM
  2. Bushmaster Help
    By shamer77 in forum Tips and Tricks
    Last Post: 07-26-2005, 08:48 PM
