Dan Gervae
Upper Peninsula of Michigan
I was doing splash and dashes in my T-Craft on floats tonight and twice it quit on takeoff....I'd be on the step...full power and rotating...seemed worse when I rolled it onto one float....I leveled off and pulled the carb heat on the last sputter and it cleared up and ran so I could get home....I took the bowl off and there was a little bit of crud in there...I was thinking carb ice but I was using carb heat on my approaches....It did start running again when I pulled the carb heat...I flew it home with the carb heat on.....I pulled the fuel line and that was okay....I did notice the fitting in the back of the Stromberg was not as tight as could be....it appears that in order for the fuel line to clear the Hanlon Wilson Exhaust Can...the previous owner left it back an eight turn ???? Any suggestions from you guys on this....I'm afraid to takeoff untill I find out what the heck happened.....One more thing confused me....I pulled the fuel valve off and when I tried to drain the bowl...gas would barely dribble out....put the fuel back on and she rushe=s out good....I'd have thought that a full bowl would drain faster.
