Results 1 to 11 of 11
Thread: Trammel Tool
    Trammel Tool
    Does anyone know where to find a "Trammel Tool". I need one for a PA-18-95. Any help would be appreciated.
    Any good hardware store should have trammel points in stock. Then just buy a 6' section of aluminum bar stock to fit the trammel points.
    Poor man's trammel stick:
    Supplies:
    Stick of quarter round (any long stick will work)
    2 brad nails.
    One spring clamp.
    Put a brad in the end of a long stick then use a spring clamp to hold the other brad where ever you need it.
    I made mine from electrical EMT conduit, 2 couplings and two sharpened screws.
    2 sharpened eight penny nails stuck through some hose clamps tightened onto a length of 5/8 tube. Adjust by loosening up one clamp.
    Brian.
    I have a set of these and really like them. $30 is worth it to me.
    http://www.aircraftspruce.com/catalo...trammelpts.php
    Henry Ford
    Trammel Tool
    I have the same ones Steve.Most hardware stores seem to have them fo short money.
    I use sharpened sticks and small C-clamps. Plus, I do it more than once in each bay, and I stretch a string along the forward spar. Only way I could get it more accurate is with a magnifying glass and a precision mark on the bolt head.
    Here's one you could make in about five minutes for a few bucks.
    http://www.woodworkingtips.com/etips/2007/03/09/sn/
    Marty57
    N367PS
    www.xanga.com/martyfeehan
    Thanks for all the help. I really appreciate the responses.
    also note if you are going to make them that the points are ground off center on the rods, and rods can rotate to give you the fine adjustment in this...
  1. Tool Definitions!
    By islandmonkey in forum Lighter than Air - Flying Humor
    Last Post: 11-25-2007, 03:01 PM
  2. tool kit
    By harleybubba in forum Tips and Tricks
    Last Post: 08-18-2004, 04:33 PM
  3. PA-12 Bungee Tool
    By PA-12 Super Cruiser in forum Super Cub Sick Bay
    Last Post: 12-31-2003, 09:16 AM
