Palmer wind
Well here is my two cents for what it is worth. I spent all night outside trying to keep my planes tied down and a few others but I have learned a few lessons. Spar strap tie downs work. Every one of my pipers had pulled rings. If I didn't have fuel trucks, vans and the like in front of my planes, there would have been more damage like the other poor chap. The biggest thing that would have saved me is if the tie downs were aligned not with the prevailing wind but with the large velocity wind direction(if that makes sense). The wind blew 010-020 most of the night at 80plus. The tied downs are all at 050. The wind was blocked from the main part of the wings but the damage to the tie down/spar, etc. came from the gust hitting the tail and trying to spin the aircraft. As the airplanes hopped sideways and torqued on that upwind spar fitting it simply twisted it right out of the airplane. If I had the Atlee stuff, it would have not been a problem, except in the rudder where it was bouncing around. (check the rudder cable bolts, I have new bolts with wear from the wind). Lastly, for hours I watched and re-roped airplanes down because they didn't have the tails of the rope tied. As the wind blew the tails flicked around and untied themselves. EVERY ONE OF MY (12) RATCHET STRAPS FAILED they were the small ones I had as backups to the ropes. The big straps all survived. By the way I fell on my ass at 3 am trying to see what the crash was and slid across 50 feet of grass, hit ice sped up then hit dry pavement. It took me 200 feet to slow down. Thank god for carharts.
