Results 1 to 8 of 8
Thread: Front trim pulley pciture needed
    supercub's Avatar
    Apr 2002
    736
    I need a picture or pictures showing the relationship of the two front trim pulleys. What I'm looking for is the approximate angle/offset or whatever you want to call it of the lower single groove pulley to the upper double groove pulley.......anyone have a pic of this. Thanks
    Brian
    tcraft128's Avatar
    May 2006
    St. Marys GA
    782
    Here is a link to the drawing that shows this. Thank Christian for the drawings.
    http://supercubproject.com/drawings/pdfs/A3250023.pdf
    supercub's Avatar
    Apr 2002
    736
    Thanks, but I don't think that shows what I'm looking for. I need to see how the bottome pulley aligns with the top pulley....I believe it's offset and at a slight angle, but not sure.
    Brian
    Aug 2002
    AK
    258
    What you are looking for is on the fuselage dwg. If you build it per the print the lower pulley bracket almost always will still need to be tweaked for the cables to clear. Tack it then check for clearance.
    18,227
    We use the print for reference and do like Fabman sugested and tack it in place, install the cable and pulley and tweak to operate without the cables rubbing.
    supercub's Avatar
    Apr 2002
    736
    OK, sounds like a plan, thanks for the info
    DW's Avatar
    Dec 2002
    pacific northwest
    2,060
    If a picture's worth 1000 words here's a couple grand.
    DW
    supercub's Avatar
    Apr 2002
    736
    You made my Christmas ..........thanks for the photos.....those are great......at least 2 thousand words worth.
    Brian
  1. Trim pulley pin
    By bob turner in forum Tales of the PA18
    Last Post: 04-07-2010, 06:40 AM
  2. Trim Pulley Bracket Wear
    By Darrel Starr in forum Cafe Supercub
    Last Post: 05-24-2005, 01:53 AM
