Dennis and Cubflier, Hello.
Yes, I can tell you what it is, and yes, I have a picture of one.
The "Custom Cruiser" is heavy. It is a Smith PA-12 replica with 5, count 'em, 5 doors, aux tanks, full metal headliner and interior, 4-Atlee long steps, etc....................................................................................................etc....................................................................................................etc..................... performance-wise, you would be blown away that a heavy "Cub" would fly like this. It proves that the aerodynamic mods on it are working. This aircraft will turn around on its wingtip when slowed-up.
First, the picture, showing an inboard and an outboard spoiler. The outboard spoiler is coupled proportionally to the ailerons only when the aileron-droop has been selected. Also, the inboard and outboard spoilers are both deployed simultaneously and symmetrically on both wings as a
descent spoiler system, which is aLOT of fun.:
This roll spoiler system mimics the Helio Courier "lift interrupter" system in shape of the blade. The blade is about 29 inches in span and deploys about 3 inches above the wing upper surface.
It is molded carbon fiber to save substantial weight over the aluminum/steel Helio-style blade-assembly. It deploys through a slot in the upper wing surface about 6 inches aft of the front spar and is situated to take advantage of "spoiling" a portion of the high-speed air coming through the Wayne Mackey slats.
The spoiler both creates drag and interrupts lift on that portion of the wing, assisting in bank and controlling adverse yaw (adverse yaw is why we have rudders, to help keep a turn coordinated).
The roll spoiler provides very good roll authority with an aileron droop system and a Wayne Mackey slat system, with everything hanging out and the a/c at minimum controllable airspeed.
Another factor on this modified Smith PA-12 replica is that the PA-12 aileron belcrank geometry was significantly changed to provide greater differential ('up' aileron goes up more than the 'down' aileron goes down) in order that with full aileron droop selected, and the control stick racked all the way over, the 'down' aileron doesn't go any further down, but the 'up' aileron actually does go up.
This differs from some recent iterations of the droop aileron system.
