Gap seals
NimpoCub
Nimpo Lake, BC . . . AKA "the Floatplane Capital o
Since FLAP gap seals are such a GoodThing,
...how 'bout AILERON gap seals?
Sure, they'd have to allow travel both ways (up/down) but why not seal ALL the draft holes. I reckon that if it did help, it would be a common mod, but my feeble brain wonders about stuff.
Maybe y'all can help me get some sleep tonight. :)
if you put them on ailerons, you must be forward with them more, in order to avoid having to cut a notch and make a dimple where top aileron cable rubs.....
this mod is usually more done to dress up an ugly wing with bad trailing edge... its a pain to do a pretty even gap job....
also it is IMPERATIVE when you install these that the wing is either installed on plane or sitting on saw horses at butt rib and AT strut attach fittings, not tip.. or wing will bow down in middle and screw up the nice gap you set....
Logan,
Who said that flap gap seals are such a great idea? In fact, depending on the type of flap your airplane has installed, flap gap seals may be a really BAD idea.
My 170 has flap gap seals, and they are terrible in my opinion.
Now, aileron gap seals on a Cessna are GREAT...
Again, it depends on the type of ailerons your airplane has.
Mike is that because the 170B flap is a "flying flap" that needs smooth airflow over the top as well as the bottom in order to function correctly?
I know in a gap sealess 18 and 12 I've flown that there was a lot of tail shaking going on, even with flaps retracted. Once gap seals were put on both airplanes this smoothed out the airflow. No more tail shaking with the flaps retracted and they felt more effective when deployed.
Mike, I figure he is talking about a Super Cub since this is supercub.org and Logan has been rebuilding his Super Cub as seen from his posts from the last year. :lol: They seemed to work on my Pacer and Jerry (Mr. Weight Conscious) Burr has them last I saw. :wink:
I put a set of flap and aileron seals on my Stinson 108-3 and they were great.
mvivion said:
Logan wrote (red)
Like Steve mentioned, I have stock SCub flaps/ailerons. If gap seals can be a bad thing, maybe I don't understand what they do exactly. (yep, I'm not smart, but lernin')
I figgered they help prevent the high-pressure air from leaking up to the low-pressure side, and smooth out the airflow over the (otherwise) uneven top surface.
Can you s'plain what is terrible??
Can you s'plain why?? (effect on flight)
I'm wondering if it would be an advantage to me (SCub wing with stock flaps/ailerons)... something that would be noticeable to flight control.
Thanks Mike (I hope) :)
Just quit your searching, do your fixun and go fly!!!
You keep pondering, and it will be 2011 before you are back in the air! :lol:
NimpoCub said:
mvivion said:
Logan wrote (red)
I figgered they help prevent the high-pressure air from leaking up to the low-pressure side, and smooth out the airflow over the (otherwise) uneven top surface.[/color]
they are named wrong... they don"t "seal" at all, there is a small gap always.... put the flaps full down and compare to one with them(installed well) and you will see what they accomplish...
I'm still flyin, I'll drag the wings into the shop next month sometime (first sign of ice over), just getting my plans/ideas/facts aligned in my head first. Try to be helpful, 'eh George? :)
OK, then if we call 'em flap gap smoothies would that be more accurate? :)
Can ya explain just what they're trying to accomplish? I don't seem to have it right.
Anyone??
Thanks!
Logan,
I've never flown a Super Cub with flap gap seals. The Cessna has "semi fowler" flaps, and the gap seals basically defeat part of the function of those flaps. I have no idea if they would negatively affect a Super Cub.
My response was to your generic statement that "Since FLAP gap seals are such a GoodThing"
Steve,
In case you hadn't noticed, SuperCub.org seems to engage a lot of chat about airmachines other than Super Cubs......
I realized Logan was talking a Super Cub, not Cessna.
But-for what its worth, flap gap seals on a Cessna are really a dumb idea.
Just ribbin' ya Mike. Super Cubs do come originally with flap gap seals. I have no experience on the Cessna flap gap seals but a good friend of mine installed them on his 180 and hated them. I removed them and he was a happy camper.
I've heard that aileron gap seals really help the C-180 at low speeds (and I assume 182's also). I've been in that "hmm the yoke is not working" state a few times in the 180...
sj
Put the tape on aileron gap seals on a 170B and it took that scary helpless feeling out of the cross wind landing. Gave a lot better aileron feel. Craig said it was the best $100 he spent on an airplane. Put them on an early model 172 with the same result.
Ol' sittin-in-his-frame said:
Nimpo Cub,
how'd you get AK58's quote header to say moose calf molester 58? :lol:
When you quote someone, you can edit anything you like.
It's the "honor system" to leave it alone. :)
Well I got ONE email with some good info!
Usually the rest of you are good for answers. :(
Seems I'm not the only one who doesn't know exactly! :)
It's an interesting yack anyway.
On this topic, I'm looking for the Part# for the Piper aluminum flap gap seals. I can't find it in my parts manual. Would anyone have it? Also, has anyone flown a super cub without these flap seals on? Curious about the flight characteristics each way. Thanks for the help.
J
Brad, I went back and read your post, anyone else with a pirep on no flap gap seals. Thanks.
I bought flap seals from Mike Butterfield in Yakima.
After recover, I flew my cub without the seals. It felt a little bit different until I pulled full flaps, it pitched nose down pretty hard. Woke me up, almost made me pee my pants. :D
I have a little extra flap deflection, stock might not be so bad. I'd put the seals on.
Years ago I was in a hurry to fly a fresh rebuild and did the first several hours without the flap-gap 'seals'. I honestly do not recall there being any good or bad about it.
That airplane eventually got the flap-gap 'seals' and micro VG's, and is a fine flyer. That airplane flew hands off the very first flight with a by-the-book rigging job. I really felt lucky with how well that bird turned out........owner had it upside down in about 2 years......landed short of the pavement on purpose and had a bit of brakes on when he rolled up onto the pavement edge..... :eek:
Elevator gap seals REALLY work, and are an easy job on a grey airplane with grey duct tape or a white airplane with white duct tape. Simply set the elevators to full down and apply the tape evenly between the elevator and stabilizer.............. MUCHO BIEN elevator authority over stock......and even without tail vg's
Dave Calkins said:
I really felt lucky with how well that bird turned out........owner had it upside down ......
Isn't that annoying to try to make everything so nice, and done to last for 20 years..... and then half of them get wrecked within a couple years!
I had one 180 with 13 hours after rebuild they had on its nose on pavement, a nice full curl...
seems like they never dinged them before rebuild and shiny :)
Duh!! I finally figured out what you guys are referring to as "gap seals" on a Cub..... :bang
I was trying to envision some add-on or STC, or modification, NOT the dang fairings that were born there. :lol:
OK!!
Alrighty then... so now, Mr Mike, can you offer your experienced opinion on the whatever-you-callits that try to keep the air on the proper side of the wing (the flight control thingies)? :)
Flaps, ailerons, elevators?
Are flap gap seals that great? I do not have them on my 12. I have extended flaps and have been wondering about these gap seals everyone talks about. I haven't noticed any adverse effects of not having them installed on my wing. Any additional info is appreciated.
Are they pricey? Where can I get them?
What is the big difference in handling?
Richard Deblack said:
Are flap gap seals that great? I do not have them on my 12. I have extended flaps ....
you may NOT be able to add them if you have the day & Night -12 extended flaps(which are -18 ailerons donors)..
that stc has you put a left -18 aileron on right wing as a flap, and the twist in it is backwards to wing twist so flap outboard tip ends up being 3/4" wrong... to compensate for that the stc has you bend the flap hangers to get railing edge semi where it looks good.. but that in turn raises and lowers front edge of flap.. so trying to line up a gap seal is not fun... and stc says don't install them..
to get around this you need to build your flaps with the proper twist in them... then flap gap seals will fit properly
Boodie built me 2 sets with proper twist... Airframes unfortunately built last set to the blueprints which gives the wrong twist, so i need to un-rivet and re-twist them then re-rivet....
The 18 flap is an airfoil blocking the gap may not be good. it becomes a drag flap at full flaps . But at 10 degrees it produces lift notice the diff in the false spare in front of the flap much diff than the aileron how many of you out there have 12's that have flaps with aileron false spar in front of it ?? now the " WING FLAP FAIRING" directs the airflow over the nose of the flap and keeping the flap from stalling when you fly a cub without the "WING FLAP FAIRING " at full flaps the air is much more disturbed going through the gap between the flap and wing.
Steve C
Boodie built me 2 sets with proper twist... Airframes unfortunately built last set to the blueprints which gives the wrong twist, so i need to un-rivet and re-twist them then re-rivet....[/quote]
What is the correct twist I have the l/e skins off mine and can set the twist when I re skin them
