Results 1 to 13 of 13
Thread: continental O 200 constant speed prop [electric]
    Mar 2009
    timmins ONT
    28
    Is anybody using a constant speed prop on a O 200
    woodcomp propeller??
    vesta propeller??
    GT propellers ???
    aerotek 2000 ???
    MT propeller ???
    any info of experience of these prop would be appreciated
    2 blade or 3 blade with revers???
    Mar 2005
    324
    Guys use the Aero-Matic. Not a controllable constant speed but close. Check the cessna 120-140 forum. Some of those guys are using them if i remember right.
    Jan 2008
    3gv
    387
    I have new aeromatic on my pa18-95 and like it. Go to www. aeromatiic.com for more info.
    Jan 2008
    3gv
    387
    Whoops, typo. That's www.aeromatic.com
    2,439
    Ivoprop makes an electrically operated controllable prop (2 or 3 blade) but not approved for certificated airplanes as far as I know. I've heard MT makes or will be making an electrcially controllable prop also.
    Eric
    Jul 2009
    YKM, WA
    6
    Quote Originally Posted by garyh
    Could you share with us any performance data? Do you have a much higher cruise speed? Any improvement in fuel economy? What about take off distance and climb?
    Mar 2009
    timmins ONT
    28
    aeromatic prop
    I call ivo for a continental O 200 prop
    the prop that they sell was 68'' 2 blade Magnum
    68'' 2 blade is not good for floats
    i will be ordering a aeromatic prop this winter and i will post the performance information.
    Jan 2008
    3gv
    387
    I will retrieve my speed data from hangar today and post tonight. I had a mac7147 cruise prop before the aeromatic. My TC specifies max length of 73" for the aeromatic and i bought a F200-73 from Tarver Propellers. As i recall the cruise speeds are about the same but now the RPM's, out of the shoot, are 2620 instead of the 2390 that i got with the mac and that was what i was after because at gross wt. on an 85 degree day the 95hp needs all the boost it can get.
    Mar 2009
    timmins ONT
    28
    aeromatic prop
    engine continental o 200 zenith 701 on floats
    macc 71/ 46 2300 rpm 402 lbs of trust
    macc 71 42 2460 rpm 439 lbs of trust
    warp drive 70'' 3 blade 6 degrees at tip 2480 rpm 461 lbs of trust
    all test were done same day with a digital tack and a digital scale
    macc 71/46 prop is 70''
    macc 71/42 prop is 71'' 1/4
    macc 71/42 is 10 ++ mph faster then the warp drive at that pitch setting
    macc 71/ 42 rates of climb is 450 ft per Minuit at 45 mph
    warp drive 3 blade 70'' rates of climb 700 ++ ft per Minuit at 45 mph
    Jan 2005
    wasilla ak.
    342
    HAve you researched the vesta very much??? What made you decide on the prop you used?? I am also in the market for a composite 3 blade for a helio on floats 96-100".
    Mar 2009
    timmins ONT
    28
    aeromatic prop
    Vesta does not support direct crank shaft application
    is prop is for REDUCTION DRIVE engine
    Jan 2005
    wasilla ak.
    342
    yes reduction drive, There is an adapter that goes from 20 spine to a standard hub. Long props in constant speed are hard to find.
    Jan 2008
    3gv
    387
    DorianJ,
    Airspeeds with Mac 7147 and Aeromatic F200-73:
    2000 rpm 75 70
    2100 80 74
    2200 83 80
    2300 89 88
    2350 92 92
    these numbers are from my pa18-95 and the pull at 2300 was 375# with aeromatic.
    gary
  1. Constant speed prop
    By Alaskan-18 in forum Modifications
    Last Post: 02-27-2006, 02:44 PM
  2. Constant speed prop on a PA-12
    By Speedo in forum Modifications
    Last Post: 03-13-2005, 09:42 AM
