Results 1 to 25 of 25
Thread: painting vg's
    banner tow pilot's Avatar
    Jun 2007
    Atlanta, GA
    71
    painting vg's
    just bought a set of micro vg's and was wondering if rattle can paint from home depot or ect would stick to them?
    8,880
    Like any aluminum.... the prep is the key!
    Clean
    Etch
    Alodyne (sp)
    Paint
    or
    clean
    use acid etch primer
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,317
    the brand that I buy are already etched and alodined.
    It's the brand you should buy, too.
    rattle can works great if you don't have any left over polyurethane paint from the latest cover job.
    Go MicroVortexGenerators!
    DAVE
    May 2006
    3,019
    Quote Originally Posted by aktango58
    Clean
    Etch
    Alodyne (sp)
    Paint
    I kinda winced when I read that... I've just spent many days doing that unpleasant job, but I'm doing floats, and they're about 99' long & 77' around. I'm through the alodyne step, now to leak test & seal 'em, then the paint (lacquer). That rhymes with liquor 'eh... I need'a'nuther drink now that you've reminded me.
    17,996
    Like Dave posted, they are ready for paint, no primer or anything else needed. I tape a piece of green tape upside down and set the VGs on it. Double sided tape would probably work well to if the stick-em doesn't transfer.
    Jun 2007
    Atlanta, GA
    71
    hey thanks guys, i figured yall would know the answer.
    10,115
    Mine were rattle can painted as described 12 years ago, and nine years of that, they lived outside.
    Paint has oxidized just a bit on them, but still not bad after all these years.
    8,880
    You can tell how long mine have been on!
    Actually, a guy here is a dealer and installs them for me, much easier.
    thanks for correcting me
    Dec 2002
    Oregon
    73
    VG's, Etch?
    OK, now I'm really showing my ignorance...what do you do to 'Etch' these little guy's?
    8,880
    Chris,
    acid etching and alodyne(sp?) process is done with chemicals that are purchased from your paint supply house.
    It was taught to me that you take the acid and scotch bright and scrub the aluminum real well. The acid will foam.
    You then use clean water to rinse and negate the acid.
    Let dry
    apply alodyne to aluminum and let dry...
    However, as corrected above, the VG's come pre coated, so ready to prime.
    aviationinfo's Avatar
    Feb 2007
    Southwest WA
    711
    I was told that with the Micro VGs if you are using a yellow to be sure to prime them 1st, otherwise they tend to have a green tint. Haven't tried it yet, anybody else have yellow MicroAerodynamics VGs?
    Theirs are already alodined.
    9,811
    I think you meant "alodyne rinse and then dry"
    10,115
    aviation info, mine are Micro, they are yellow, and no they didn't turn greenish. That was a number of years ago, however, so maybe they've changed their process. Mine were not primed when I got them, just alodyned and acid etched.
    Jul 2002
    Anchorage, Alaska
    5,317
    Quote Originally Posted by mike mcs repair
    Yeah, for sure never let alodyne dry on the parts. It should be rinsed off with clean water while the alodine is still wet on the part. D
    3,137
    Ok, I'll broadcast my ignorance here - again -
    What happens if you let the alodyne dry?
    17,996
    Paint a light coat of white and then yellow. I use white over silver and then color and I use a white primer over metal. Helps bring out the color and takes less paint.
    10,115
    Yeah, it takes almost an eighth of a can of Krylon to paint a set of VG's.......
    Sorry, smart ass factor just kicked in there...
    Jul 2002
    Anchorage, Alaska
    5,317
    Quote Originally Posted by 12 Geezer
    I heard from 'them' (yeah, whoever 'they' are) that if you allow the alodine to dry, it will actually promote corrosion. This may have been mentioned in the tech info. for the etch/alodine process.
    D
    May 2004
    Lafayette La
    311
    I put a set of rattle can painted Micro's on my Husky amphib. They were still in good shape 7 years later when I sold the plane. Bill
    Jun 2007
    Atlanta, GA
    71
    thanks guys for all the reply's. i think i am going to go with black to match the stripe on the a/c.
    cubhunter's Avatar
    Jul 2005
    hibbing,mn./sidelake,mn.
    156
    paint VGs
    Banner tow pilot,like Steve said masking tape sticky side up with tape about every foot to hold it down, place the VGS on the tape, than I self etch primed them and I painted them blue the color of my stripes,the plane was lite grey so the blue VGs looked good against the grey wings. Pat
    PS I used enamel from auto paint store, they matched my color and can put it in a rattle can for you alittle more money but worked well.
    10,115
    And, when you glue em on the wings, use twice as much glue as specified. Never had one come off.
    17,996
    Quote Originally Posted by mvivion
    You lost me there Mike. Never seen the amount of glue specified. If you use too much it squirts out all over the mask and makes a big mess to clean up and all the clear glue you miss turns yellow when it dries and really looks bad.
    Jul 2002
    Anchorage, Alaska
    5,317
    I have made tiny 'notched trowels' that I derived the notch size from trial and error to place exactly the proper amount of glue each time with no muss or fuss.
    I use a q-tip to apply the 'primer/catalyst' to the masked/template area and am able to avoid spraying that stuff all over.
    PS I 'heard' from 'them' (not the vg folks) that using 'self-etching primer' over an already etched/alodined part is a bad thing. I recall 'them' saying it promoted corrosion to do so. Wish I could remember where I got this 'information'.
    D
    10,115
    Steve,
    The set on my airplane specified verbiage like "Use the minimum amount of adhesive".
    My point wasn't to use so much that it seeps out everywhere, but rather get a good coating of adhesive between the VG and wing.
    Sorry, wasn't specific enough.
  1. Painting the PA-12
    By randywhite in forum Tips and Tricks
    Last Post: 01-21-2009, 12:45 AM
  2. Painting VGS
    By behindpropellers in forum Tips and Tricks
    Last Post: 09-05-2008, 09:33 PM
