Results 1 to 13 of 13
Thread: Transporting Uncovered Wings
    Grant's Avatar
    Woodbury, MN
    1,567
    What is the best way to transport uncovered wings on an SUV.
    behindpropellers's Avatar
    NE Ohio
    6,603
    Re: Transporting Uncovered Wings
    Quote Originally Posted by Grant
    Grant-
    I think if you are going to have any chance of transporting them through any salt I would rent a box truck.
    You might be able to pay Dakota cub to pick them up (I think they deliver their wings).
    marinelubricants's Avatar
    Nov 2003
    57
    Grant: go to a yacht yard and see if you can buy the shrink wrap and borrow their propane torch for shrinking the stuff. We were thinking of doing this to pick up our Smith kit in Canada on our 5th wheel trailer in the winter. Than we were able to borrow a big enclosed trailer. Are you getting back into the Cub Building Business? All the best, Jerry
    Grant's Avatar
    Woodbury, MN
    1,567
    Thats a great idea Jerry.....These are not my wings, I'm just helping load them up.
    NE Ohio
    6,603
    Quote Originally Posted by marinelubricants
    Thats a good idea but I would be leary of the shrink bending stuff??
    Cub junkie's Avatar
    My Moms basement
    1,978
    Another idea, wrap them in cheap tarps from Harbor Freight aircraft supply. Lots of duct tape too.
    6,130
    Easier to wait until it is dry. I have had no trouble transporting bare wings. Support them with 2x4s at the butt rib and at the lift strut attach points. Use plenty of carriage bolts, and check them now and then as you go.
    Lance's Avatar
    Jun 2002
    Gonzales, Louisiana
    677
    Grant,
    I cut notches in some 2 x 4's and sandwiched the spars and bolted the 2 x 4's together. Worked well.
    Lance
    Aug 2003
    1,276
    Lance's idea is sound.
    But go look at a sailplane trailer, e.g., a Schweizer for open. It'll be much like Lance described.
    Or get some nasty Thrift Store bedsprings, sandwich the lot, lash down with some rachetstraps from the same Chinastore (Harbour Freight....), recheckyour load regualarly...
    Thanks. cubscout
    Howard Shepherd's Avatar
    May 2005
    S.E. Alaska
    48
    Last May I bought a set of assembled wings after the Alaska Airman's Trade Show. A friend helped notch some 2X6s to fit the boat rack on top of my camper shell. We removed the leading edge metal just outboard of the tank bay and behind the landing light to allow clamping the spars between the 2X6s. There were spacer blocks with all thread, fender washers and nuts to clamp the spars and keep them from contacting the boat rack on the bottom and more spacers to keep the wings apart. Ratchet straps held everything to the boat rack. I drove from Anchorage to Juneau via Fairbanks with no problems of any kind. When I unloaded the wings in Juneau there were some bug splatters to remove.
    Remember... It's better to give ulcers than to get them.
    6,130
    Three 2x4s per wing. Two sandwich the spars inboard of the butt rib, using very long carriage bolts. The third is attached to the spar attach points using the original bolts, plus a pair of eye bolts to draw the 2x4 up against the steel attach fittings. Bulletproof, so long as the bolts stay tight. Lash or bolt the 2x4s to the truck or trailer firmly. Interstate speed limits are OK, and I have done transcontinentals this way.
    Lance's Avatar
    Jun 2002
    Gonzales, Louisiana
    677
    I did it the way Bob describes.
    Lance
    Roger Peterson's Avatar
    May 2004
    Sweeny, Texas
    1,454
    I just brought a set home to Texas from Nebraska in a covered Cattle Trailer. Put 2/6's through the sides and bunged the wings to the 2/6's. Still have room for the rest of the plane in the trailer. Works great.
    Roger
    Based at O8XS. Sweeny Texas (Winter)
    Finlayson Lake, Ontario (Summer)
    I plan on living forever.......so far, so good !!!
  1. Transporting Wings
    By PA18project in forum Experimental Cubs
    Last Post: 12-06-2006, 05:46 PM
  2. Landing gear uncovered
    By rplemmons in forum Modifications
    Last Post: 01-06-2004, 10:50 PM
