Hi Kirk
Yes, that is correct - I have cut off the last few inches of the bracket (the end that holds a mixture cable). If you look closely at the photo you will see a tiny black dot near the end of the bracket. I intend to drill a hole there & bolt an Adel clamp to hold the mixture cable. I am using a plain wire end type of mixture cable. The Vans bracket is made for a "threaded end" type of mixture cable - I dont have the clearance required for a threaded end mixture cable, however I believe that the plain wire end type of mixture cable will work well in this application. I felt it was important to have the control cables mounted off the engine rather than off the engine mount. My build is an "Experimental" so I dont know the legal process if you have a "Certified" PA18
