nanook
northern alaska
Use the Sensenich prop for higher MP.
Nothing wrong with below freezing temps, better than above 80 temps... Carry some power in to land/ high drag with a shallow approach.
How confident are you in your (or your A&P's) work? Double and triple check everything... You are the flying test stand, key word "test"... Stay in the pattern in the orbit mode. Above 75% power setting... Do an hour, if it looks/feels good stay up for another hour... Land and do a quick check, you are looking for oil/fuel leaks and loose parts...top off the oil sump. Run at max oil level!!! Oil absorbs and removes heat...
It only takes a couple hours to seat the rings (if done properly) you are looking for a drop in CHT, and oil consumption. Follow the Lycoming instructions for engine break-in. Make a log book entry stating that you did I/A/W...don't exceed the airframe limitations when using high power settings...
