to further muddy the waters:
in the Alerts Mr Mandell states that the measurement of washout should be -.7 deg at the outer aileron rib when the aft point of the level is under the rear spar.
using that calculation and assuming he got the 2.5 deg washout from some Piper source, not his own calculations, the bottom of the spars should read 1.8 (or thereabouts)
however, he says the angle of incidence
measured at the centerline of the spar hing bolts should be 1.84 deg
I just don't get that statement.
thirdly in his calculations that cubflier sent, he uses the full length bottom of the rib for his final figure to get 1.84 and says that the rear spar is .28 above this line. He admits there is a .2+ discrepancy and this is the more accurate measurement.
so even he uses three different lines he calls AOI, and only the one referring to the centerline of the bolt is close to the true AOI, but nowhere close to 1.84.
all I do know , is that when I measure an airplane that has 1.8 deg at the bottom of the spars, I get 2.75 inch diff between the heigth of the front and rear spar bolt C/L (Max allowed by Piper), and when I measure an airplane that has 1.5 deg at the bottom of the spars I get the factory spec 2.5" measurement
