Results 1 to 29 of 29
Thread: Wing Incidence
    Boise Idaho
    160
    Wing Incidence
    Does anyone know what the wing incidence (at the root) of a super cub is in relation to the waterline or centerline of the fuselage? The reason I ask is we are in that stage of building a Breezy fuselage and it calls for 0 incidence at the wing root and I had thought that a cub had 1.5 degrees... but I can't remember. Thanks Joe
    Feb 2004
    Mt.
    1,282
    incidence
    Joe, From the horizontal reference line on the fuselage to the bottom of the wing at the first rib the magic number is 1.84 degrees. Most seem to measure somewhere between 1.2 and 1.7 unless they have been rebuilt in a jig recently that puts it all in. You might want to check with Mark E from Thrustline on all this. He has all these numbers in his head.
    Dave
    jgerard's Avatar
    Nov 2004
    Seattle, WA
    894
    Since the Breezy is a pusher with the engine so close to the wing you have to consider all the important numbers that affect the flight characteristics. Wing and tail AOI, TL, method of trim (tab vs' moveable stab) and C.G.
    Jason
    8,859
    The L-21 maintenance and erection manual says that the angle of incidence is 2 degrees 2". at the root. This corresponds closely with the bottom of the wing being level.
    If you can find a copy of 'Handbook of Airfoil Sections for Light Aircraft' by M.S. Rice you will find on page 74 all of the specs for the U.S.A. 35B airfoil which is on the Cub. That should accurately answer your question.
    S2D's Avatar
    Montana
    4,025
    Has anyone come up with the angle between the bottom of the rib and the chord line of the supercub rib yet?
    I measured the straightest butt rib I had and came up with 1.9 deg.
    that measures closely with what skywagon says about the botton of the rib should be level when the plane is level.
    cubflier's Avatar
    Nov 2003
    1,267
    There should be 2.5 inch difference between the front and rear attach fitting. After you attach the wings the incidence at the root is the 1.84 degrees. The best measure of this is using the bottom spar caps and not the ribs since things can vary.
    At least this is how the great one (that is currently chasing Kipper Snacks) told me how to do it.
    Here is another thread on the subject.
    http://www.supercub.org/phpbb2/viewt...wing+incidence
    A link to rigging instructions.
    http://www.faa.gov/aircraft/safety/a...7_08_Alert.pdf
    Here is the drawing of the attach points. Note the attach points are not at 1.84 degrees and I forgot the angle. You can use the drawing to solve the math if you need that figure.
    [/url]
    Jerry
    If it looks rough...it is!!
    S2D's Avatar
    Montana
    4,025
    thanks Jerry. I've got those figures from the same source.
    that figure is great for determining the proper alignment of the fuselage , but it doesn't give me the angle if incidence of the wing at the butt rib. The actual rib determines that.
    I just want to know what my true angle of incidence is.
    both my butt ribs are new dakota cub ribs and both measure exactly the same at the bottom, so the angle of incidence should be that figure plus the difference between the rib and the chord.
    X + 1.9 = AOI (if 1.9 is the correct angle between the bottom of the rib and the chordline)
    cubflier's Avatar
    Nov 2003
    1,267
    Quote Originally Posted by S2D
    Wouldn't the answer to your question be 1.843 ( the wing incidence measured from the bottom of the inboard rib) + 1.9 (your measurement)= 3.743.
    Is there a practical reason for knowing this figure or are you just pontificating?
    Jerry
    S2D's Avatar
    Montana
    4,025
    Quote Originally Posted by cubflier
    Jerry
    Kinda just pontificating, but if it was 3.743 (which I didn't say it was) , that would be quite a bit over factory specs
    Plus I want to know the relative angle compared to the trim range of the horizontal stabilizer before I have it covered.
    incidently, both my ribs measured .3 deg less than the bottom of the spar measurement.
    8,859
    I checked on the Northland CD. Piper drawing 13814 is the rib outline which gives all of the coordinates. If my math is correct the angle of incidence to a straight edge along the lower surface is 1.54 degrees.
    S2D's Avatar
    Montana
    4,025
    I come up with 1.61 deg, but I used an online angle calculator
    thanks 8A that will give me what I need.
    8,859
    S2D
    You got me thinking about our different answers of .07 degrees. I found it. Dwg. 13814 shows that the trailing edge is 0.164" thick. The chord line goes through the center of the trailing edge. If you use my center line the answer is 1.54 degrees. If you have the trailing edge come to a point then the answer is 1.61 degrees.
    S2D's Avatar
    Montana
    4,025
    sounds good to me, I'll use yours
    found out why I'm .3 off from the spar too. bottom of rib wasn't flat.
    so cubflier was right on that part, unless I put a straight edge on the bottom of the rib.
    S2D's Avatar
    Montana
    4,025
    Re: incidence
    Quote Originally Posted by ag-pilot
    From the horizontal reference line on the fuselage to the bottom of the wing at the first rib the magic number is 1.84 degrees. Dave
    Dave can you tell me how that number was arrived at?
    Seems too exact to be a figure that Mark just decided works best.
    (I could understand 1.8 or 1.85 but to come up with 1.84, he must have calculated the difference between the bottom of the spars and the true chord)
    If it is the measurement at the bottom of the spars, what is the true AOI of the wing on a supercub.
    SuperCub MD's Avatar
    Jan 2002
    Collins, Wisconsin
    1,344
    Brian,
    Airworthiness Alerts
    Service memo #19
    The numbers are all in there, if you do the math and cook it all down it comes to this.
    PA18
    Level at door bottom
    Butt rib incidence +1.843
    Last full rib incidence -.717
    Wing washout 2.56
    PA12
    Level at floor between gear fittings +1.665
    Butt rib incidence -.060
    Last full rib incidence -2.627
    Wing washout 2.567
    Tolerance is +/- 1/4 degree.
    Use a 30" straight edge on the rib bottoms between the spars to account for the curve in the ribs. I've got the numbers written on the shop wall so I don't have to keep looking them up.
    S2D's Avatar
    Montana
    4,025
    Quote Originally Posted by SuperCub MD
    Thanks Mark, I'll look up that Service memo,
    but for posterity's sake (pun intended)
    please define "Butt rib incidence".
    So far I've seen it measured three different ways, none of which give the same reading.
    1. Bottom of spars
    2. Bottom of rib
    3. Actual cord of wing
    4. None of the above
    (all compared to the longitudinal plane of the A/C)
    only one is correct.
    Edited to include 4. none of the above
    Jan 2002
    Collins, Wisconsin
    1,344
    Brian,
    This should be the same as the bottom of the spars. Everyones favorite fish watcher likes to use the spar bottoms to check the frame, and I agree this is more accurate for the frame, ribs can be tweaked. I use the 30" straight edge between the spars when rigging. Can't check the spar bottoms on the outboard rib with fabric on.
    I'd say 1 and 2 are both correct. The cord line wouldn't even be close.
    Here is the AC. Read it and work it out. I'd bet a beer or 2 that my numbers are right....
    cubflier's Avatar
    Nov 2003
    1,267
    I was in agreement with your numbers until (very recently) I broke out the plans and did the math. I also measured the spars on a set of wings I have in my hangar and came up with an angle substantially less than 1.843 and very similar to my math calculations using the plans.
    Then I looked at the methodology behind the 1.843 number. The man (Gordon Mandell) that wrote the AC did not use the bottom of the spars in his calculation of the 1.843 number. It's an average of two methods taking the angular difference in the horizontal reference line of the wing bottom and the horizontal reference line of the fuselage. At least this is my interpretation of his notes.
    I have his notes and methodology and would be glad to send them via email if you like. I'm interested to see if you draw the same conclusions that I have and if I'm wrong will be happy to buy you that beer or two.
    Jerry
    Jan 2002
    Collins, Wisconsin
    1,344
    Jerry,
    I'd like to read the info you have. My e-mail hasn't been working well lately, but give it a try if you want to,
    drath@lakefield.net
    If it takes much more than elementary math, I'll probably just drink beer.
    Crash's Avatar
    Apr 2002
    Nikiski Alaska
    2,695
    Jerry
    Jerry; you're now seeing and maybe fighting the same problem I had with the numbers last year when you and I went round and round over this.
    They're less in actual practice and I don't know why. I pulled my hair out over this!
    Did the measurements on a set of un-covered wings and a fuselage with wings mounted. The math on the fuselage was right on the money but that is where everything ended.....
    Crash
    S2D's Avatar
    Montana
    4,025
    [quote="SuperCub MD"]
    Brian,
    you may need to load that cub up with beer when you come out this winter Mark, but I'll digress until I get home and study Jerry's document again.
    I've also edited my original multiple choice above
    cubflier's Avatar
    Nov 2003
    1,267
    Jerry,
    drath@lakefield.net
    Mark,
    I emailed the document to you last night so let me know if you did not receive it. I look forward to your opinion on this.
    Jerry
    S2D's Avatar
    Montana
    4,025
    to further muddy the waters:
    in the Alerts Mr Mandell states that the measurement of washout should be -.7 deg at the outer aileron rib when the aft point of the level is under the rear spar.
    using that calculation and assuming he got the 2.5 deg washout from some Piper source, not his own calculations, the bottom of the spars should read 1.8 (or thereabouts)
    however, he says the angle of incidence measured at the centerline of the spar hing bolts should be 1.84 deg I just don't get that statement.
    thirdly in his calculations that cubflier sent, he uses the full length bottom of the rib for his final figure to get 1.84 and says that the rear spar is .28 above this line. He admits there is a .2+ discrepancy and this is the more accurate measurement.
    so even he uses three different lines he calls AOI, and only the one referring to the centerline of the bolt is close to the true AOI, but nowhere close to 1.84.
    all I do know , is that when I measure an airplane that has 1.8 deg at the bottom of the spars, I get 2.75 inch diff between the heigth of the front and rear spar bolt C/L (Max allowed by Piper), and when I measure an airplane that has 1.5 deg at the bottom of the spars I get the factory spec 2.5" measurement
    Jan 2002
    Collins, Wisconsin
    1,344
    I'm sure I'm stating something you all ready know, but this gave me some confusion when I first looked at this. Maybe it will help someone trying to measure a bear frame.
    The AOI line is parallel to each individual front and rear spar attach bolt hole, not a line between the front and rear spar attach fitting bolt holes.
    I haven't gotten the e-mail yet, but my computer has been very constipated. I'll give it a while to see if anything develops.
    Glad I only bet some beers and not a bottle of Jack. It seems there has been evidence withheld, and the question altered after I answered it? I think I have grounds for a mistrial, certainly an appeal to a higher Court. I'd hate to think I can't even measure my own butt. And I will not divulge the measurements of my own butt. I'll plead ignorance, most times I can't even find it with both hands and a flashlight.
    FdxLou's Avatar
    Apr 2004
    1,746
    Boz, you crack me up!
    Congratulations on the new addition to your Family.
    See you in N'olstein.
    Lou
    S2D's Avatar
    Montana
    4,025
    Can anyone verify or refute these figures
    distance from center of spar attach bolt to top of spar:
    Front spar: .531"
    Rear Spar .614"
    I got the front one from the Northland drawing and had to figure the rear one using the Piper drawing and trig.
    If these are correct, I come up with the same figures cubflier does, but not positive they are correct.
    cubflier's Avatar
    Nov 2003
    1,267
    I solved from the bottom but if I subtract from the spar heights I get
    Bolt CL diff from top of spar
    Front = .531
    Rear = .618
    Bolt CL diff from bottom of spar
    Front = 5.156
    Rear = 3.382
    These measurements are in agreement with Gordon's calculation #2 and very close to what you have.
    I could not find enough information to solve the equation from the top of spar so I had to work my way up from the bottom and subtract the spar height.
    Jerry
    cubflier's Avatar
    Nov 2003
    1,267
    Mark,
    I posted the info here
    Good luck.
    Jerry
    S2D's Avatar
    Montana
    4,025
    PA18
    Wing washout 2.56
    Guess you won't have to bring the beer Mark. Your numbers are close enough to count. Just not for the reason Gordon Mandell gave.
    (as long as you define rib incidence as the measurement taken directly under the spars) on an airplane with maximum tolerance at the spar hinge fittings
  1. wing incidence stinson
    By wheat in forum Cafe Supercub
    Last Post: 04-15-2008, 02:28 PM
  2. Wing angle of incidence
    By Laz in forum Tips and Tricks
    Last Post: 02-01-2004, 09:57 AM
