Results 1 to 18 of 18
Thread: Firewall blanket advice?
    Dec 2005
    Fairbanks, AK
    278
    What is the best firewall blanket for the PA-18? Price? Availability? Specs?
    Thank you,
    Vickie
    behindpropellers's Avatar
    NE Ohio
    6,563
    Re: Firewall blanket advice?
    Quote Originally Posted by tamarack
    Thank you,
    Vickie
    Add J-5/PA-12 to this question's answers.
    CubLite's Avatar
    Mar 2003
    BUCYRUS, KANSAS
    361
    Just bought the Wag-Aero stock for the J-3. 2 Feet, by 36 inches. Was $20.25 running foot, so $40.50 plus shipping- $12- thought was way too high. Could not find one ready made to fit.
    Pat
    GREEN SIDE UP
    16,776
    The last two I bought were from AirTex. Have to look up price etc. It fit well.
    Darrel Starr's Avatar
    Plymouth, MN
    2,524
    I'm getting a lot of heat through the stainless firewall with the big Leading Edge muffler setting there real close to it. I am thinking of trying to slide a piece of "Koolmat" (sold by Aircraft Spruce) between the muffler and firewall -- might be just enough space for this 0.070 thick mat. Has anyone tried this or possibly have another solution to the heat soaking through the firewall? I have an Aircraft Spruce normal quilted cover on the inside that looks good but that probably does little good to stop the heat transfer.
    Thanks, Darrel
    "Crazyass passion is the staple of life and persistence its nourishing force. Without them, you cannot cross the trail" - Rinker Buck
    Speedo's Avatar
    Jul 2002
    AK
    1,645
    Check out the products used on racing cars to isolate heat sources. Here's one source: http://www.pegasusautoracing.com/keywordsearch.asp . Use the search term "insulation" and you'll find many alternatives.
    Eric
    Speedo
    bobnall's Avatar
    Hillsboro, OR
    339
    I used Airtex. About $70 if I remember, is cut to fit, and is approved. Had to do a little trimming, but nothing major. Was an easy fit, and lots of color choices. I went with the Dove Grey.
    Bob
    Plymouth, MN
    2,524
    Eric, thanks for that Link - great stuff:
    Here are examples of the material I am thinking of -- one from Aircraft Spruce and one from Pegasus. Anyone have a similar issue? Anyone trying a similar product?
    Thanks, Darrel
    16,776
    I have used the Koolmat on fiberglass cowlings that were too close to the exhaust. The cowl quit getting soft.
    FdxLou's Avatar
    Apr 2004
    1,591
    I have the Leading Edge Exhaust on my Smith Cub. The heat transfer was unbearable until I put Koolmat on BOTH sides of the firewall...only one side will not do it.
    I did all this after the plane was flying...what a pain. I had to remove the muffler to do the front side and cut sections to go on the inside. I put it on with hi temp ( Red ) RTV. No problems in 800 hrs.
    Lou
    Plymouth, MN
    2,524
    Lou
    Your comments really help!
    Thanks, Darrel
    May 2006
    300
    I visited a local aviation upholstery shop and they have a nice approved firewall blanket material. Grey on one side, with a diamond shaped pattern. Fiberglass or similar in the middle. I am going to supply a cad drawing of my widebody firewall, and their machine will cut it precisely. They will then sew a 'closing strip' around the edges, including the inside of the round holes. If there are others interested, I could get more than one made at the same time to help offset some of the setup costs. (send me a pm)> I need some help on how many hoes to put in it: so far:
    1) 4 engine mount holes
    2) fuel pipe)
    3) starter cable
    4) cabin heat
    5) ??
    Aerodon
    8,387
    oil press/temp
    P leads
    electric
    Bugs66's Avatar
    Feb 2004
    Spokane WA
    2,295
    I bought Airtex and was impressed with the quality.
    gdafoe's Avatar
    782
    Anybody used ARMAFLEX for the firewall? I'm using it on some of the other panels for sound deadening. Also thinking of using it inside the firewall.
    Gerald
    May 2006
    3,009
    Quote Originally Posted by Aerodon
    2) fuel pipe)
    3) starter cable
    4) cabin heat
    5) ??
    Don't forget your tach cable, it goes ~ top center, all by itself.
    May 2006
    300
    Thanks Logan, I found the 'firewall layout' picture on my CD Rom. Also the firewall drawing (#12365) which fortunately matches my widebody firewall. Now I know it starts getting wider at that point. Here are pictures of the blanket material, I'm planning on getting 5 made up.
    Hope the pictures work,
    Aerodon
    kase's Avatar
    MT
    1,506
    Airtex Firewall.
  1. Firewall Blanket
    By supercub in forum Experimental Cubs
    Last Post: 12-07-2009, 01:01 PM
  2. firewall blanket
    By ag-pilot in forum The Art and Science of Flying
    Last Post: 08-12-2005, 07:01 AM
