Results 1 to 3 of 3
Thread: 45 Degree scat flange
    nd
    3,102
    Would any one know of a place that sells a flange for off the back of the engine baffling for the 2 inch scat hose that comes out at a 45 degree. Every place has straight ones but cant find any at a 45. Or even a used one? doug
    Clearwater,Fl
    2,519
    I had a local welding shop make mine. I used thin wall stainless. A little over kill but all I had for raw material with a 1.9 OD. I think in was 049. Easy to weld. another approach is to cut the end of the tube at a 45 and weld in on a flat plate instead of the traditional 45 fitting welded to a flat plate.
    Jan 2005
    wasilla ak.
    342
    aircraft exhaust inc. in princeton mn. will build you one. These guys are great to deal with unlike most aviation services.
  1. 1 degree change = how many RPM?
    By High Country in forum Cafe Supercub
    Last Post: 04-22-2009, 07:37 AM
  2. J5A with A-75 Scat Hose Issues
    By rrb in forum Everything Else (formerly:My Other Plane Is A....)
    Last Post: 08-04-2006, 07:58 AM
