Results 1 to 12 of 12
Thread: Thrust Line
    Mar 2005
    Normandy TN
    314
    Thrust Line
    I am starting an exp cub project using some Pa22 parts and a Spraker fuselege. I am confused on the thrust-line issue (and many others). Is the thrust-line on a factory supercub 4 degrees downward? On the newly approved STC is the thrust line adjusted to zero? If I build a engine mount that is parallel (firewall side of mount parallel with engine side) will this be a zero thrust line and a desireable goal.
    Jim Miller
    Mar 2005
    Normandy TN
    314
    Thrustline
    I have answered my question. I have acquired a drawing CD which shows the 4 degrees downward tilt. Does anyone have an opinion on whether a swing out mount is necessary. Is this feature used a lot in maintenance or rarely enough to get by without it on an experimental.
    Jim Miller
    Feb 2004
    Grand Rapids MI
    93
    Love my swing out mount I feel it's worth the effort.
    nd
    3,102
    Jim, i was wondering what angle of incidence your wings are mounted to your spraker airframe? doug
    Mar 2005
    Normandy TN
    314
    Doug
    The fuselege is being made for Dec pick-up. I am planning on using Alaska airframes fittings and installing same as a standard supercub. Any advise on this subject is welcomed.
    Jim Miller
    Charlie Aileron's Avatar
    Aug 2002
    4GA4 Chatsworth, Georgia
    326
    Hi Doug, I built my "Crimson Cub" using a Spraker fuselage and Airframes fittings. I am by far not an expert, but if I can help you in any way feel free to contact me. 706-695-1435, 706-280-9550 I am not too far from your location, just a bit southeast of Chattanooga, Tn.
    Charles Aaron
    SteveE's Avatar
    Feb 2006
    Jenks, OK
    4,165
    Jim,
    Don't let Charles fool you by his humbleness. If he offers his phone number, call it!!!
    Mar 2005
    Normandy TN
    314
    Charles
    I will certainly take you up on that offer. I saw your plane on Mr Spraker's website. I live in Tullahoma, Tn and can easily fly my Colt down to your location sometime also. I will be giving you a call soon. For reference here is my contact info : Jim Miller (931)455-8662 jimmiller2@cafes.net
    Jim Miller
    New Haven KY
    32
    Hi Jim I made the swing out mount but have not used it yet. Come up and see my cub anytime if you like. Kenny
    Jul 2006
    32
    thrust line
    You will have your work cut out for you if you are going to make yours look and fly as good as Charles' !
    Doug
    Mar 2005
    Normandy TN
    314
    Thrustline
    Ken
    I will definitely take up up on that. I am always looking for a reason to fly my Colt. I go to Madison, Indiana frequently to visit relatives and will stop
    by.
    Jim Miller
    Clearwater,Fl
    2,519
    I just measured up my experimental and from what I can tell, using a digital level, I have a neutral thrustline. I measured the bottom longeron,the one between the gear attachment points, and then measured the angle difference between the motor mount lugs. I got a reading of 89.5 degrees positive, or a half degree up. What does this mean? No thrustline mods required?
  1. Thrust Line Mod -- What is the bottom line?
    By JMBreitinger in forum Cafe Supercub
    Last Post: 02-04-2005, 05:13 PM
