Doug,
I knew it....did not expect any less reaction...
Thanks Doug for your personal contribution in building part of Brutis. You, your team and Bud did a great job.
As to gross weight: I understood from Byron Roots, that the GW was established partially on the basis, that that same spar was also used on Pawnees, operating at 2500lbs. I stand corrected...
My initial comment only contained a big Hmmmmmmm, which was related to price and a contemplated price increase for Brutis.
My reference to the two planes being similar applies, if you look at the specs. Similar is not equal, better or less. E.G. Brutis, as you know, can carry 72 gal. which makes for some long legs, has a payload (@ 36gal, or half fuel) of 850lbs, attributes I like.
I also look at power plants. I personally prefer that 6 cyl. - smooth - at low compression over a 10:1 4 cylinder. In a pinch I can always use some car gas..... Longevity may be an issue too...?
Empty weight is only 400 lbs more than the Carbon Cub. The additional hp and the 39 ft. +/- wing compensate for that somewhat.
Static trust. I may agree with you, Doug. The 90" Sensenich prop on Brutis is not optimal. A constant speed MT would improve the overall static trust. 18k for Prop, Hub, Spinner & Backplate, Governor and control would take care of that. I pm you my bank account for a contribution....
Long story short, Brutis' price tag is cheap! Maybe the message get's across to some potential buyer....so I can go and order that Found Expedition......
Cheers
