Results 1 to 7 of 7
Thread: Aluminum repair question
    Martinsburg WV
    45
    Has anybody out their ever used a aluminum repair product called HTS 2000? Looks like it might fix small cracks in cowlings or skins but thought maybe someone has either used it or seen it?? Any input?
    Jeffpa12
    Sep 2006
    520
    Here's the Website www.aluminumrepair.com It looks kinda neat
    18,116
    Seen it at the fair.
    behindpropellers's Avatar
    NE Ohio
    6,638
    Jeff-
    Post some pics of what you are trying to fix. Somebody will be able to help you with your cowl...
    btracy's Avatar
    Apr 2004
    Ohio
    1,000
    It is not really a weld it is more of a brazing type of process. It is very hard and brittle. It does not seem to go on very smooth (unsightly globs). I think on a cowling with the vibration level that it would just crack out again.
    6,382
    I have had reasonably good results with flush rivets, by using JB Weld in the sandwich and on the rivets before squeezing. An extremely thin coat of bondo seems to survive the heat and vibration, although after a few years you may see a hairline crack in the paint here and there.
    Clyde and Susan's Avatar
    Dec 2005
    602
    In places where I have stop-drilled a crack I put a nice glob of RTV on the underside out of sight. That stops a crack in its tracks. I also use a thin layer of RTV on patches to the J-3 eyebrows. Those patches have held up for years. That has worked on my Fairchild F-24R and my fith-wheel travel trailer as well as the J-3. I haven't had any sheet metal repairs needed on the PA-11 so far. The RTV remains flexable and it's a good adhesive. ...Clyde
  1. Aluminum TIG?
    By Scouter in forum Cafe Supercub
    Last Post: 11-26-2010, 08:17 AM
  2. D&E Aluminum Struts
    By Bugs66 in forum Experimental Cubs
    Last Post: 06-08-2007, 11:34 AM
