FdxLou said:Both the Swiss water bags and the Alaskan Bushwheel model were never meant for ANY ethanol...mogas is OK as is 100LL...just be sure there is no ethanol, not even 5%. The rubber will decompose and do bad things to the carb, etc.
Lou
OLDCROWE said:I washed mine out with non-alcohol car gas then let fuel sit in them for a month and strained it through a paint filter and found nothing before refilling them with 100LL using them... And SteveE’s hose works wonders especially if you bevel the outside of one end a bit.
I bet the factory knows what it's talking about too.Actually according to the factory the bags we stock will do fine with Ethanol
hottshot said:FdxLou said:Both the Swiss water bags and the Alaskan Bushwheel model were never meant for ANY ethanol...mogas is OK as is 100LL...just be sure there is no ethanol, not even 5%. The rubber will decompose and do bad things to the carb, etc.
Lou
Grant said:Has anyone had any luck finding a non-valved , non-vented cap for these "Water" bags?
jrussell said:While there are several options, I like to go with a known entity that supports SC.org and stands behind everything they sell. I bought a Alaskan Bushwheels 5+ gallon bag along with Bill's handmade fill valve accessory and it works beautifully. You just lay it on the wing and it will fill the tank in seconds. Plus, you can't put a price on the comfort of having a bit of extra fuel on board when you are out and about the wilds of Maine, New Hampster and Verminont.
spinner2 said:jrussell said:While there are several options, I like to go with a known entity that supports SC.org and stands behind everything they sell. I bought a Alaskan Bushwheels 5+ gallon bag along with Bill's handmade fill valve accessory and it works beautifully. You just lay it on the wing and it will fill the tank in seconds. Plus, you can't put a price on the comfort of having a bit of extra fuel on board when you are out and about the wilds of Maine, New Hampster and Verminont.
I bought one of these this month. It looks like a quality fuel bag. I haven't used it yet on top of a wing but will. I didn't see anything on ABI's site about a handmade fill valve. Maybe Wup can chime in?
brown bear said:Cut off cap , then drill and tap for 1/8" pipe ,then use pipe plug for transport. For fueling install a 1/8 pipe to 3/8" hose fitting with a 24" rubber hose on the fitting, lay bladder on the wing , it works great and takes about 5 min. to drain
DW
DW
Bump...all of the previous links are 404d, is this the 'water' bag of much fame?View attachment 28321
I don't know anything about they company, but there is a phone number and contact info listed under the "About Us".
http://www.sportsmansguide.com/prod...CPgNxhuG3uzxqOjB6qC62_cLAcjanAK17URoCoo_w_wcB
