Results 1 to 33 of 33
Thread: shock cord installation tools J3/PA11
    May 2004
    Lafayette La
    311
    I want to buy a shock cord tool. Need advice on which is the easiest and best. The last one I saw somebody using looked as dangerous as a Bear trap, especially when a lever slipped and it threw parts all over the shop. Saw 2 sold by A/C spruce, any advice or comments would be appreciated. Bill
    behindpropellers's Avatar
    NE Ohio
    6,582
    Bill-
    I think if you are a mechanic and you do this often it is good to have the tool. But if you are only going to do one or two sets of bungees a year I think the best deal going is to buy a set from Univair and send your shock struts and let them put them on for you.
    May 2004
    Lafayette La
    311
    Tim, you are probably right. That is what I did last time. I've got 2 planes now with the same shock system. I'm trying to weigh cost vs convenience if I can figure out which tool is best. Bill
    May 2004
    Lafayette La
    311
    Sep 2002
    1,621
    It takes about 30 minutes to make a 3/11 bungee tool, using maybe $5 worth of materials. A piece of 1"x2" rectangular steel tubing about 30" long, a short piece of 1.5 inch round steel tubing, and two small pieces of 1/8" steel plate. I highly recommend having one around the hanger.
    JimC
    May 2004
    Lafayette La
    311
    Jim, do you have a photo or drawing of the tool? I have access to a skilled welder, just need to show him what I need. Would appreciate details and dimensions. Bill
    Jan 2002
    Meadow Lakes, AK
    391
    There are plans for two different bungee tools in the member area under tech articles and forms
    May 2004
    Lafayette La
    311
    Thanks,DJ
    17,143
    Doug and dan Stewart have a nice one that works on everything except a Clipper or a PA12.
    http://www.aircraftfinishing.com/products.aspx?cid=3
    Nathan K. Hammond's Avatar
    Nov 2002
    Danville, KY DVK
    477
    Hi Bill, I don't think we've met, but I'm Clay's little brother. The simplest and least expensive way to change bungees is by using an engine hoist, and a piece of metal channel or angle.
    Here's how it works:
    We knocked a hole in the metal so the strut could fit through, then slide a screw driver through the bolt hole to keep it in place. Next take a piece of scrap rope (1/4" braided seems to work the best, doesn't break and is a small diameter) and make a loop to catch the bungee. Start stretching the bungee using the hoist, you might find it easier if you spread the rope (black hammer in pic). Once you've got the bungee over the ears, release the hoist pressure, cut the rope and use the hoist to pull the rope free of the bungee. When you've got the strut off the airplane, use a piece of chain to hold the airplane up. Just be sure to use bolts and not drift pins.
    Here's the benefits of doing it this way: One guy can do the entire job in about an hour. There is no real grunt work; the hoist picks up the airplane while you remove the struts and insert the chain and the hoist stretches the bungee. No lever to spring back, and no screw drivers to damage the bungees. It pulls evenly on both sides of the bungee. It's safe for you, the strut, bungee and the airplane. It only cost you a piece of rope; you can use the local FBO's hoist and scrounge for a scrap piece of steel.
    Hope you enjoy the SportCub, I had the pleasure to fly on it's wing from Iowa to Georgia while it was being delivered.
    nkh
    Snert's Avatar
    Mar 2006
    Raleigh, NC
    1,758
    Now that's ingenious!
    Sep 2002
    1,621
    John Scott has photos of a good bungee tool here:
    http://www.j3-cub.com/index.php?opti...g2_itemId=2479
    Mine is similar, except that I use a longer handle. I tend to clamp the strut in the vise, and swing the tool rather than clamping the tool and swinging the strut. I can send you a dimensioned AutoCad drawing of my tool if you wish.
    JimC
    Clearwater,Fl
    2,506
    I have built the one JimC is refereing to. But its more like 17 dollars worth of steel if you have to buy it. You will need a good strong table vice to use this tool effectively. It is easy to make though. RRB could give us an operational report. Where are you RRB.
    May 2004
    Lafayette La
    311
    Nathan, I knew there was a simple way to change cords! Thanks for the photos and instructions, I'll file the information till I need it. Bill
    May 2004
    Lafayette La
    311
    Jimc, I would like to have the dimensioned drawings. Do you need an address or will you e-mail them? Thanks for the help, Bill.
    Sep 2002
    1,621
    Bill, I'll e-mail it to you. I'll have to run out to the airport tonight and measure it. You can e-mail me at jrccea at bellsouth.net
    It will be an AutoCad drawing. Would you prefer the file in dwg or dxf format?
    JimC
    NE Ohio
    6,582
    Jim-
    Can you copy me on it too.
    May 2004
    Lafayette La
    311
    Jim, thanks for the trouble, dwg format would be best for me. Bill
    Clyde and Susan's Avatar
    Dec 2005
    602
    I used the engine hoist method and it was fast simple and safe. That's how I will do it in the future when needed. ...Clyde Davis
    rrb's Avatar
    Aug 2003
    325
    FortySix12 and I fabricated the tool mentioned by JimC above.
    My experience is from my J5 with three light bungees (the ones also on a J3) per shock strut.
    The three bungees per side lead to some difficulty because strut's ears don't hold the third bungee on, rather it sits in the groove between the first two. So, we kept losing the bungee when swinging the strut around and ultimately had to use a C-clamp to keep it on. The first two bungees, however, went on easily without any problems.
    Mar 2014
    2
    Jim C
    could you please send me your dimensional Auto Cad drawing of the bungee tool. Thank you
    Little_Cub's Avatar
    Feb 2011
    Palmer, Alaska
    264
    Not a CAD drawing but this might work..
    Had to mark it up with marks-a-lot to keep the kids from throwing away what looks like junk.
    Been using the same one for 20+ years.
    good luck
    frank
    Little_Cub's Avatar
    Feb 2011
    Palmer, Alaska
    264
    Mar 2014
    2
    Thank you Frank, I'll give it a try.
    SteveE's Avatar
    Feb 2006
    Jenks, OK
    4,002
    Quote Originally Posted by Little_Cub View Post
    good luck
    frank
    Little Cub, I am sure you have installed the 1280HD bungees on a supercub, but just confirming this, because those bungees are STRONG. With the hydrosorb on the supercub, does this tool still work? It makes it look really easy. Does the bungee ever try to slip off the round piece when you are at the highest angle?
    SteveE
    8,778
    SteveE;597505]Little Cub, I am sure you have installed the 1280HD bungees on a supercub, but just confirming this, because those bungees are STRONG. With the hydrosorb on the supercub, does this tool still work? It makes it look really easy. Does the bungee ever try to slip off the round piece when you are at the highest angle?
    SteveE
    Steve if your not strong enough to flip your bungee by yourself we can take a collection up and get Timmy a ticket to come out and give you a hand.
    SteveE's Avatar
    Feb 2006
    Jenks, OK
    4,002
    Haha. I'm just wondering if that same tool will work with the hydrasorb and with the hd bungees. I can do it the okie way too. Why don't u make me one and send it this way and stay off the computer......
    Little_Cub's Avatar
    Feb 2011
    Palmer, Alaska
    264
    Yes it gets a bit nerve racking with 1280's (these were 1080's in the movie) it would help to place a light bead to better retain the bungee.. most of the time it works as planned.
    Disclaimer: use at your own risk!
    SteveE's Avatar
    Feb 2006
    Jenks, OK
    4,002
    I can see you better hang on... Ive got enough weight on me, but it would launch Tim back to his family in the White House.....
    Thanks LC
    DesperadoPilot's Avatar
    Jan 2009
    Brazoria, Texas
    412
    Eaton you never fail to crack me up, lol.
    I fly IFR (I Follow Roads).
    Dec 2014
    2,512
    Quote Originally Posted by NC40867 View Post
    Jim C
    me too please!!!
    Eddie
    cruiser's Avatar
    South Glens Falls, NY
    1,315
    Modify that tool to fit into a 2" receiver hitch in case your vise and bench is not as stout as shown in the video. Those bungee's may move your bench but probably not your truck.
    Jun 2016
    1
    Thanks for the ideas in this thread
    Hi All,
    My first post here, but a longtime Cub owner. I just wanted to say thanks for this thread. I used Nathan's engine hoist approach to shock cord replacement today, and it worked great.
    Let me contribute an idea, too. Once the shock struts were removed, I used one of those farm tractor three point hitch stabilizers to hold all in place. The are readily available from any tractor supply store, are inexpensive, strong, and very adjustable. I couldn't find my other one, so I just used a chain for the other side.
    So all you farm kids will be ready next time your Cub needs landing gear work!
    Best to all, Jeff
  1. Shock Cord Covers
    By harleybubba in forum Products, Purchases, Reviews & Prices
    Last Post: 09-06-2009, 03:48 AM
  2. Shock Cord Tool
    By kase in forum Tips and Tricks
    Last Post: 11-20-2002, 05:26 PM
