Len has actually aided and abetted my perfidy. He gave me a pair of older struts which get rotated on and off every two years. Len, and I, and others obviously including the FAA, think these struts are perfectly safe if they are checked and corrosion-proofed. However, a number of us are starting to worry about linseed oil peeling off the bare steel surface, thus allowing corrosion. I may convert to some other fluid next summer - I'll pick a very warm day, hoping that all the linseed oil will heat up and roll out, then flush with turpentine.
An aircraft parked outside, not being flown, is a target for discrete corrosion. It doesn't make any difference what you do, the water will get in there, and sit forever in the same spot. Deadly. The cure is daily flight, and/or a hangar.
