Results 1 to 3 of 3
Thread: C90 Prop seal
    C90 Prop seal
    48 hrs SMOH on my cubs C90. The first prop seal started leaking at
    10hrs. It was just noticable on windshield after a 2hr flight. I installed
    a new seal 4hrs ago, all was good untlil today. I am starting to see
    the little dots on the windshield again. The engine has great oil pressure
    (40psi) even when hot, is this to high? The case was OH and a new
    crankshaft installed. Any tips on installing a new seal.
    Thanks, Jon
    Fond du lac Wi.
    http://www.supercub.org/phpBB2/viewt...highlight=m764
    Go down to my post with the links. I had the same problem with the C90 in the L18C.
    Henry Ford
    Thanks Steve ! I will give it a try. Jon
  1. Prop Seal
    By Brett Evans in forum Super Cub Sick Bay
    Last Post: 03-01-2006, 07:07 PM
  2. Prop Seal
    By JP in forum Cafe Supercub
    Last Post: 08-09-2005, 08:37 PM
