Results 1 to 11 of 11
Thread: P/N 40721-00 Stabilizer Adjust Cable Rubbing Block
    BES's Avatar
    Jun 2002
    Esbjerg, Denmark
    445
    Can anyone tell me what this block (stabilizer trim cable circuit) is made of? Univair asks $25.00 for one. If it is just a wooden or rubber block it must be possible to make one, or?? Does anyone have a photo of one??
    Bent
    behindpropellers's Avatar
    NE Ohio
    6,634
    I would probably make this out of HDPE and make it as small and light as possible.
    BES's Avatar
    Jun 2002
    Esbjerg, Denmark
    445
    Thanks Tim.
    Appreciate it!
    Bent
    nd
    2,988
    Go to your Wicks aircraft catalog and look under phenolic sheet, postage will be your only expense. doug
    17,924
    Bent, I might still have a sheet of phenolic at the hanger. If you want I will check tomorrow and I can send you a piece big enough to make the part.
    Dave Calkins's Avatar
    Jul 2002
    Anchorage, Alaska
    5,312
    I make 'em out of 1/4" UHMWPE (ultra high molecular weight poly ethylene)
    ...but I'm gonna start making them out of HDPE (high density polyethylene) to save a bit of weight.
    ...just like Behindprops does .
    NE Ohio
    6,634
    Quote Originally Posted by Dave Calkins
    such a pain in the a$$
    Doesn't atlee use a HDPE rub strip on his ext baggage mod where the trim cable rubs?
    Jul 2002
    Anchorage, Alaska
    5,312
    Yeh, it's white plastic, anyway.
    BES's Avatar
    Jun 2002
    Esbjerg, Denmark
    445
    Steve, thank you for your kind offer. However it would be quite a bit of postage... I think I'll try some of the UHMWPE.
    Thanks for all the prompt and very useful info.
    Bent
    nd
    2,988
    I was looking at pipers faa print above and over the description it says fiber board. hmm doug
    BES's Avatar
    Jun 2002
    Esbjerg, Denmark
    445
    In that case I think I'll use black plastic...!
    Bent
  1. Flap rigged to adjust ailerons
    By johnlinde in forum Member to Member
    Last Post: 08-12-2007, 10:23 PM
  2. Trim cable rubbing on extended bagage compartment
    By palhal in forum Modifications
    Last Post: 03-10-2004, 09:49 PM
