Results 1 to 35 of 35
Thread: Heads up: Really Nice PA-12 Experimental in Sport Aviation
    Bugs66's Avatar
    Feb 2004
    Spokane WA
    2,299
    Just got my Sport Aviation mag from EAA. Right on the front cover is a beautiful experimental PA-12. Good story to go with it too.
    Check it out.
    Janesville,WI
    309
    Better yet you should see it perform live and in person. Nice airplane.
    Matt
    17,982
    Is that Tom Hegy's PA12? I haven't gotten my SA yet.
    Found it on-line. http://www.eaa.org/benefits/sportavi...11_feature.pdf
    Tom is a great guy and pretty anal about airplanes. Crop duster by trade.
    behindpropellers's Avatar
    NE Ohio
    6,637
    Looks nice but does not seem like anything out of the ordinary???? Seems like most of those mods are STC'd anyway.
    "A stock PA-12 topped out at 115
    mph, cruised at 105, and climbed at a
    sedate 650 fpm. According to its GPS,
    397JH cruises at 135 to 140 mph, and
    lightly loaded (pilot and half fuel)
    has an initial rate of climb around
    2,000 fpm. It gets off short, Tom says,
    and lands slowly, which has always
    been two of the Super Cruiser’s most
    admired traits."
    135mph? HUH??
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,113
    Wow! That reads like an ad for a Maule!
    NE Ohio
    6,637
    Another thing...
    Why mention FPM climb in a cub?? Climb angle means a lot more to me than FPM.
    Nov 2003
    Anchorage
    837
    Someone forgot to add that it weighs only about 1105 lbs and never stalls!
    If you believe everything you read around here, you might suffer from a good case of cub envy .
    Janesville,WI
    309
    Steve P yes it's Tom's. Believe the numbers that airplane flat out moves.
    Matt
    Bugs66's Avatar
    Feb 2004
    Spokane WA
    2,299
    Steve,
    Thanks for posting the link to the article. I didn't realize you could read all of SA online.
    As a side note, did anyone else notice that this new issue of SA seemed light years better than before? I was interested in every story. I was starting to get frustrated with SA because they kept having $300k certified aircraft stories and seemed to be straying from EAAs homebuilding roots. Anyway, this new issue seemed to eliminate that problem. I quit subscribing to Flying magazine because it is designed for John Travolta jet jocks. Keep up the good work SA!
    Aug 2002
    277
    I agree with Matt.
    I've seen the plane with my own four eyes.
    Mark
    Cubpylut's Avatar
    Aug 2002
    Madison, WI (C37)-Brodhead
    105
    Like my brother Matt said, seeing is believing. Tom has had the PA-12 in to Brodhead on several occassions. The worksmanship is excellent and his attention to detail is outstanding. I would recommend reading the article before critizing his claims too much. Remember, he has spent a lot of time on fairings including the gear and struts. He has also installed a tapered rod style tail spring and small tail wheel like used on RV's, Tailwinds, etc. Take off performance is impressive and watching it fly in the area, you can tell the airplane is faster than your normal Cub type aircraft. His mods may not help it get in and out shorter or handle rough terrain, but getting from point A to point B is where this airplane is going to shine. Just my $0.02.
    James
    (If my Rebel was as fast as it sounds, I'd have been there yesterday!)
    Oct 2003
    Paducah, KY
    408
    Not too many people can build a whole airplane folks! If someone finds out I am building one they look at me like "Have you lost your mind"or "Don't ask me to fly with you". So my hats off to him. I am with you on the eaa mag being a little high end Buggs and have considered not getting it anymore so this issue was better. Paul one has a mag called To Fly which is full of how toos and articles of early EAA type planes being built. I read my dads but it is only bimonthly I think. It also has on the cover that it is from the sport aviation association.
    Mar 2003
    Tampa, FL
    59
    Seeing is believing
    I have seen it with my own eyes, I have a hangar at Hartford and Tom did a super job of keeping it light and making it go really fast. You should see the TravelAir he scratch built. Note the gear is 12 and faired, all the wheels are smal, and no one has a tighter cowl.
    17,982
    Tom is pretty anal about drag. He pointed out several things on my Clipper that were slowing it down. There was an article on his 12 several years ago in Cub Clues. He did some things Piper should have in my opinion.
    Nov 2003
    Anchorage
    837
    Have some perspective here! Aviat added 30 more Hp, a high performance exhaust, a constant speed prop, a wing with a different angle of incidence and different flaps and still didn't increase the airspeed and rate of climb numbers simultaneously by as much of margin over the 18, which was already super slow, as this guy did with a 12 by making less obvious changes.
    If he did this, Cessna, Aviat and Cub Crafters have had some serious sand kicked in thier face .
    17,982
    He is running at least 50 more horse power and know on Tom a helluva lot less drag. Doesn't seem unreasonable to me.
    T.J.'s Avatar
    Apr 2002
    Alaska
    3,211
    delete
    Nov 2003
    Anchorage
    837
    T.J.,
    But it is a Monte Barrett engine, so it is reasonable that it can climb 2000 ft/min. with a 74" prop. At least, that is what the article is trying to tell us.
    How could I become a disciple of The Tom?
    17,982
    Come down to Broadhead, WI the second weekend in Sept. and sit around the campfire. If Tom isn't out spraying he will be there along with a lot of other very talented and friendly folks.
    T.J.'s Avatar
    Apr 2002
    Alaska
    3,211
    delete
    17,982
    TJ, It is great time and you would fit right in. I know from the article that Budd Davidson wrote on my Dad and I several years ago that they get facts screwed up. Regardless of that Tom is s very talented builder and pilot. I would be curious to see his true airspeed.
    Barrett Performance Aircraft build a lot of aerobatic and high performance experimental engines along the lines of Lycon.
    http://www.bpaengines.com/site.html
    jnorris's Avatar
    Wisconsin
    785
    Quote Originally Posted by T.J. Hinkle
    I will retract all the above statements, when I see it.
    TJ, Ground Loop, and all,
    I HAVE seen it! I can confirm everything that's claimed for Tom's airplane. I've flown the airplane several times and have verified the numbers. The airplane is all that it claims to be.
    Joe
    Nov 2003
    Anchorage
    837
    For the record I think Barrett is one of the best/ the best rebuilder in the country. I would choose him over Lycon.
    Remember,that cruise and climb require different types of props to maximize performance. He maximized both significantly with a cruise prop.
    Put that airplane on floats with that prop and what kind of numbers do you think will show.
    SuperCub MD's Avatar
    Jan 2002
    Collins, Wisconsin
    1,343
    It would have been nice if they would have shown some pictures of the fairings, cowling, and the fit and finish on this plane. The true experimenters and knuclebusters would be impressed with the attention to detail Tom has done. This is probably the slipperyest Cub on the planet, and also defies the increasingly common building theme of "heavy is better", and shows what a well thought out light Cub with a good engine can do. It was built by a owner who knew his specific needs in the airplane, and built it accordingly. It is not a Alaskan dead moose hauler, but if you are not hauling dead moose, I don't see anything wrong with that. More owners would be better off if they built their Cubs for what they really need, instead of what they think they need.
    Nov 2003
    Anchorage
    837
    SuperCub MD,
    I smooth always better and faster? How much percentage difference can fit and finish make with the same aerodynamic design?
    Jan 2002
    Collins, Wisconsin
    1,343
    Quote Originally Posted by ground loop
    SuperCub MD,
    Well, smooth is usually good if you want to go fast, I don't think this is any kind of revelation. As a contrast, I probably have one of the dirtiest, draggiest Cubs to ever break ground. It was built for a entirely different purpose. Sometimes drag is good.
    Nov 2003
    Anchorage
    837
    Super Cub MD,
    Dimples?
    Aug 2002
    277
    Ground loop,
    How smooth is your pocket - 10K says I can blow away any 12 or 18 in your big belt buckle, small dick Alaska with a Chicago 12!
    Mark
    Nov 2003
    Anchorage
    837
    mmr,
    It sounds like you have a very special 12. Can you please tell us more about it?
    If you bring it to the Valdez fly-in this year you could put it up against the best . You will also get a good laugh out of how badly I do against the best .
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,113
    Ground Loop,
    Good answer. I thnk MMR may have had a few too many Old Styles when he posted that one....
    Remember, little bobby and little susie are trying to learn how to be real pilots from this forum also.... (scary, I know!)
    Crash's Avatar
    Apr 2002
    Nikiski Alaska
    2,695
    Quote Originally Posted by mmr
    Ground loop,
    Mark
    Hey, hey here! You're hitting pretty close to home with that comment. I happen to have a small belt buckle and we're not all from Texas as you imply. Crash
    Aug 2002
    277
    Good One Crash!
    Mark
    T.J.'s Avatar
    Apr 2002
    Alaska
    3,211
    Ah, come on Steve, they gotta learn how to cuss also, don't they?
    SJ's Avatar
    Jan 2002
    Kansas City, USA
    14,113
    Cuss? I thought he was talking about hiring a very short detective to fly the plane for him...
    Aug 2002
    277
    I'm sorry Ground Loop and everybody else and your right sj!
    I've got Verne Troyer ("Mini-Me") lined up but having problems
    with the rudder pedals and brakes.
    Mark
  1. Nice Experimental Cub Parts
    By KOZ in forum Cafe Supercub
    Last Post: 03-11-2007, 08:10 PM
  2. Replies: 27
    Last Post: 07-18-2004, 04:02 PM
