Looking for the best engine and prop cover around. Any advice is appreciated. Thanks
If you do a search, there are several discussions on wing and engine covers on this site. I've used both Cunningham and those made by Alaska Wing Covers. Both were excellent.
I would have them slightly modified by leaving an opening with a flap at the front intake to allow heated air to circulate if using a combustion heater. It makes a noticeable difference in heating times if you can let the air circulate.
Mike
