How do you install the thing? Flight Simulator 2004. I got all 4 cds installed. I put cd 1 in, and click RUN and it goes back to windows menu!
I'm not a computer type person so I have no idea how to do this!!!
Redtail;
On mine...after the 4 CD's are installed....you run disk # 4 everytime to initiate the process...then click on the MICROSOFT FLIGHT SIMULATOR 2004 icon on the start menu...or the shortcut icon....
Good luck.
If that doesn't work...see Alex's solution...
Randy
We figure we dont enough memory or graphic disk.
Might go back and buy another memory disk and graphic card.
But heres the thing.
We go through all 4 CDs and then it still doesn't work. You click on RUN and it seems like it goes to work and all of a sudden just immediently goes back to the menu screen.
You click on the sim icon, and nothing happens untill you put in Disk 1 and the same thing happens.
We do have enough space on the computer though.
Register it?
Check the RAM (memory) and graphics card requirements on the back of your FS CD covers. Most systems have barely adequate memory, but often the graphics card needs upgrading.
Using Tom's site recommendation the specific help you need should be available.
